Thread: 255 tires
Results 1 to 12 of 12
  1. #1 255 tires
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    Right now I am running 225x55x17 on my 2000 gtp. will 255x45x17 or 255x50x17 work? will they rub in the front?
  2. #2 Re: 255 tires
    The rims can play a big factor in that. If a lower offset, they will rub.
    A 245 tire is usually what most people run, no real reason to go wider.
  3. #3 Re: 255 tires
    Feb 2010
    Nampa, ID
    the only reason is a good deal on them (free to almost free) and my 17's are pretty high offset I think 35 or 40...
  4. #4 Re: 255 tires
    SWPA
    Stock 225/55/17 are 26.74" in diameter. 255/45/17 are 26.03" in diameter. 255/50/17 are 27.04" in diameter.
    Neither of those 255 sizes are optimal. 245/50/17 is the optimal size if you want to go wider. It is 26.65" in diameter.
  5. #5 Re: 255 tires
    Aug 2014
    Gainesville
    Simpler than that...
    55% versus 45% ofthe same width. Width is 225mm.
    Difference is 10% of 225, difference is therefore 22.5mm in section height.
    Near enough to one inch.
    Overall diameter has TWO section heights, so overall diameter change is... almost two inches.
    Grand Prix Forums highly recommends Sanford and Son Junk Cars to get cash on the spot for your unwanted Grand Prix Car
  6. #6 Re: 255 tires
    Quote Originally Posted by heriberd View Post
    OP is looking to run 255 not 225.
  7. #7 Re: 255 tires
    SWPA
    I did the math, it is what I said it is.
  8. #8 Re: 255 tires
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    You can use this to figure out if they fit or not:
    http://www.rimsntires.com/specspro.jsp
    Like steathee said they are either to big or to small, the 245/50/17 is what you want.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  9. #9 Re: 255 tires
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    I'd be interested too if they rub, I'm looking at a deal for 255/40/17 ( ~ 2.5 % shorter) with high offset. I ran 245/45/17 on a set of bullets and they didn't rub. tires were not tall enough.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  10. #10 Re: 255 tires
    Oct 2013
    MARYLAND
    Quote Originally Posted by MBruneaux View Post
    Those would be way too small, that is only like a 25" tire instead of the 26.7 that a 245/50/17 or 225/60/16 is
    -Thomas Fuller-
  11. #11 Re: 255 tires
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    FWIW i have 245/45(maybe?)/17 on bonneville rims and all 4 tires rub on the plastic guards. (have 225s in garage but found out left drivers rear rim has a crack, ugh)
    2001 Grand Prix GTP, silver w/ black hood, silver bullit 17s
  12. #12 Re: 255 tires
    The Boss Iceman6669's Avatar
    Jun 2011
    I currently run 245/50/16s all around on some Pregens and I dont rub at all.
    2011 F-150 Yote powered
  1. looking for 255/45/18 tires
    By painthorsemoe in forum Wanted To Buy - Parts
    Last Post: 03-09-2014, 11:35 PM
  2. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
  3. I think I need new tires...
    By SlowM90 in forum Tires & Wheels
    Last Post: 04-06-2009, 07:45 AM
