Thread: I need to know if these will fit.......
Results 1 to 15 of 15
  1. #1 I need to know if these will fit.......
    SE Level Member sheckyq's Avatar
    Apr 2014
    Middletown, RI
    I need to replace the tires on my 2005 Grand Prix GTP. Stock tire size is 225/55-17. I found some 225/50-17's and would like to know if they would fit...
  2. #2 Re: I need to know if these will fit.......
    They will fit, but it might look a tad goofy with smaller tires on there. The speedo will also be slightly off.
  3. #3 Re: I need to know if these will fit.......
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Gas mileage will also drop a tiny bit. Although if you calculate it based off the miles the car thinks it's gone it will be the same or higher.
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: I need to know if these will fit.......
    Those are bigger tires and probably will rub
  5. #5 Re: I need to know if these will fit.......
    Are you high?
  6. #6 Re: I need to know if these will fit.......
    nope stock tire size is 225/55/17 and he's asking about 255/50/17
  7. #7 Re: I need to know if these will fit.......
    Oh **** I didn't even notice that lol.
    Sent from A Galaxy Far Far Away........
  8. #8 Re: I need to know if these will fit.......
    Quote Originally Posted by Slick2500 View Post
    Because you're high?
  9. #9 Re: I need to know if these will fit.......
    Apr 2014
    Middletown, RI
    Hahaha..... yeah, next time I'll have to recheck before I post.... Sorry all!!
  10. #10 Re: I need to know if these will fit.......
    Not at that point in time no.
  11. #11 Re: I need to know if these will fit.......
    SWPA
    Quote Originally Posted by sheckyq View Post
    I need to replace the tires on my 2005 Grand Prix GTP. Stock tire size is 255/55-17. I found some 255/50-17's and would like to know if they would fit...
    Stock is 225/55/17, not 255/55.
    225/55/17 are 26.74" in diameter
    255/50/17's are 27.04" in diameter. They are also 1.18" wider.
  12. #12 Re: I need to know if these will fit.......
    Apr 2014
    Middletown, RI
    Actually, I was trying to say 225/55-17 to 225/50-17.....
  13. #13 Re: I need to know if these will fit.......
    SWPA
    225/50/17 is going to be almost an inch shorter that stock.
  14. #14 Re: I need to know if these will fit.......
    Oh in that case it'll look funny
  15. #15 Re: I need to know if these will fit.......
    Apr 2014
    Middletown, RI
    Thanks all for the help!!
