They pound in and out just fine no need to remove the bearing
I still advise against pounding on them, in either direction but especially when putting them in. You can use the C-clamp without hub removal. At least use an open ended lugnut and just tighten it to press them in.
7" Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
