We need the check engine code to help you more. Its also possible the transmission has thrown a code aswell.
As for the ABS, perhaps there is still a problem with a wire harness to a hub or the ABS module needs to be rebuilt. You will have to get the car scanned to see what ABS code its throwing. That code should tell you what wheel(s) its coming from or if its a internal fault with the ABS module.
