Thread: Fitment Problems :(
Results 1 to 19 of 19
  1. #1 Fitment Problems :(
    Apr 2012
    Bancroft. Ontario, Canada
    So I've found a set of rims i really like, but i've ran into a few problems. The specs of the rims are as follows: 17x8 et20 5x120
    Now I'm curious to know (as I want to run a thin lug adapter/spacer to run these said rims) BUT what my main concern is. What's the fitment going to be like. Or am i just wasting time, and money by buying this type of wheel and making it fit. I'm all about aggressive fitment, but not to the point where it look's like ass.
  2. #2 Re: Fitment Problems :(
    SWPA
    You're wasting your time. With a 20 offset they are already going to stick WAY out. And most lug adapters are going to be an inch thick making it stick WAYYYYY out.
    Find rims that fit, and don't stick out. You can look for 5 x 114.3. There is a much larger variety in that size than there is in 5x115.
  3. #3 Re: Fitment Problems :(
    Apr 2012
    what would be the lowest offset that would make for a decently aggressive fitment? without having them stick "WAYYYYY" out?
  4. #4 Re: Fitment Problems :(
    SWPA
    On a GP I am not 100% sure, others can speak up.
    I should test fit my 17 x 9, 30 offset Konig Villains to see how much they poke out.
  5. #5 Re: Fitment Problems :(
    Apr 2012
    ok, now another question, what about staggard setups, running a 35offset all around but 17x7.5 up front and 17x8.5 in the rear
    they should fit alright i'm guessing, can always run a thin spacer to widen the stance right?
  6. #6 Re: Fitment Problems :(
    Running different size rims won't look good on these cars.
    Stick with a offset of around +30 with a 7-8.5 rim width.
    Go with 18's to make it look better.
  7. #7 Re: Fitment Problems :(
    Apr 2012
    how wont a staggard setup look good? i'm curious to your reasoning. their an inch wider from front to back.
    as for 18's. I've toyed with the idea of 18's, and after seeing a few different gp's with 18's in person, they just seem a tad excessive to me.
  8. #8 Re: Fitment Problems :(
    It's a fwd car why would you run a staggered setup
    04 Comp G.
  9. #9 Re: Fitment Problems :(
    Apr 2012
    It's a fwd car why would you run a stagger setup
    why do the hellaflush vdub guys do it? how about the honda's?
  10. #10 Re: Fitment Problems :(
    They're gay thats why
    04 Comp G.
  11. #11 Re: Fitment Problems :(
    And hellaflush negative camber etc is about the stupidest thing you can do
    04 Comp G.
  12. #12 Re: Fitment Problems :(
    The front rims would look smaller with a different size rim than the rear.
    Its so much easier to run the same size, get the same size tires and be able to rotate the tires correctly.
  13. #13 Re: Fitment Problems :(
    Sure if its a rwd setup take advantage of being able to run more width and tire on the back but will fwd keep it simple and just run the same width and enjoy being able to rotate your tires when needed
    04 Comp G.
  14. #14 Re: Fitment Problems :(
    Apr 2012
    One does not simply rotate cambered tires..
  15. #15 Re: Fitment Problems :(
    if you're running staggered you put the bigger wheels up front, it's FWD.
    and yes, you DO just simply rotate cambered tires. you just might have to get them removed and flipped before you rotate (if they aren't directional, that is).
    all of what's been said is true, but what hasn't been ASKED....what wheels are you looking at? thought of trying to find a set in the right specs that look the same?
  16. #16 Re: Fitment Problems :(
    Apr 2012
    Looking at a set of BBS RS
  17. #17 Re: Fitment Problems :(
    are they 2/3 piece? do you need them to be legit BBS RS?
  18. #18 Re: Fitment Problems :(
    Apr 2012
    it's a grand prix.. do you think it deserves a legit set of BBS rims... lol
    No their rep's, in a 2peice..
    I've been looking to find a normal unstaggard setup, and made a couple phone call's, but i'm told the same ****.. Their being sold as a staggard setup in the specs i mentioned in post #5
  19. #19 Re: Fitment Problems :(
    1. Privat (Konig Maxxim) Remember - REMEMBER GOLD
    2. Prime 250 - Prime Wheel
    3. Image Wheels Billet 85 - Billet Wheels
    Image Wheels has some really cool retro wheels. Check them out.
    4. Konig Maxxim - Maxxim Home
    5. ESM Wheels. ESM-002GL (GL = Gold, SL = Silver etc...) - Esm-002 - Esm Wheels - Esm-002bk - Esm-002sl - Esm-002gl - Esm-002gm - Thank You for Visiting Esm
    6. Extremewheels UK BBS RS Style rims extremewheels are suppliers of alloy wheels to all models and makes of cars,audi,bmw,vw ,mercedes just to name a few so why not look at our website offerings
    7. Lenso BSX - LENSO Alloy Wheels Brand, RAIDEN Alloy Wheels Brand,Alloys wheels, Racing Alloy Wheels,Honda Alloy Wheels,Audi Alloy Wheels, Supplier of Wheels, Wheels, Rims, Custom, Racing, Wheels, Datsun Alloy Wheels, | lensowheel.com - Supplier of Car Alloy Wheel
    stole that from a website from a quick search...
    those are all the brands/models you can look at.
  1. Rim Fitment?
    By Boostdgtp in forum Tires & Wheels
    Last Post: 01-12-2012, 09:47 AM
  2. Downpipe fitment...
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 10:52 AM
  3. fitment
    By jayrodmiller in forum Tires & Wheels
    Last Post: 03-15-2011, 02:28 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. UIM 07 fitment
    By jasonball in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2009, 09:01 AM
