Thread: Offset and wheel?
Results 1 to 9 of 9
  1. #1 Offset and wheel?
    Ohio
    eBay Motors: 18 WHEELS 5x115 300C Dodge Charger Magnum Challenge RWD (item 310097046673 end time Nov-05-08 00:35:13 PST)
    Was lookin at these wheels. How does offset work? What would a 20 offset look like on our cars? Would they be sticking way out or be nestled way back in?
    00 GTP demodded and forsale
  2. #2 Re: Offset and wheel?
    Ohio
    Also is 9 too wide considering im on stock wheel studs not arps?
  3. #3 Re: Offset and wheel?
    that offset is probably going to be too low for how wide the rim is. youre going to want to stick to the mid 30s for a good offset on these cars.
    they would stick out and more than likely cause rubbing problems.
  4. #4 Re: Offset and wheel?
    Ohio
    Alright thanks bio thats exactly what i wanted to know
  5. #5 Re: Offset and wheel?
    if you were able to test them out without buying them i would be all for you trying it to see how they worked out, but its a large waste of money if youre just going to have to sell them again.
  6. #6 Re: Offset and wheel?
    Ohio
    Yea no way to test them so ill pass on the idea.
  7. #7 Re: Offset and wheel?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    I saw those a while ago in 18x9s with a 30+ offset. Those should work, but 9" wide and +20 offset. Thats going to hit the fenders
  8. #8 Re: Offset and wheel?
    Jul 2008
    Germantown, Maryland
    all 4 for $200.... and those are sme pretty nice rims... i like those!
  9. #9 Re: Offset and wheel?
    SE Level Member 89prix's Avatar
    Oct 2008
    phoenix az
    I put stock 300c wheels on my 89 with 245 45 zr 17 all i had to do was put a 8th in spacer on the front for caliper clearance. no rubbing dont know on newer GP's
  1. Offset: +40mm
    By xbnb1978x in forum Tires & Wheels
    Last Post: 08-10-2008, 04:22 PM
  2. will these 19's with 35mm offset work?
    By merked in forum Tires & Wheels
    Last Post: 07-24-2008, 06:13 PM
  3. wrong offset bullitt wheels
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 01:22 PM
  4. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
