Thread: Which tire should I run on my Bonnie GXP wheels
Results 1 to 20 of 29
  1. #1 Which tire should I run on my Bonnie GXP wheels
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So its time for some new rubber, I live in WA where is rains a lot. I am in Real Estate so I drive a ton, and I mean a ton like average 2k a month just for work. So I want some handling and life. I was thinking OEM as I know most times the OEM tires on decent wheels are typically good tires but im open to suggestions?
    Stockers/Goodyear
    Goodyear Eagle RS-A
    Pirelli
    Pirelli P Zero Nero All Season
    Firestone
    Firestone Firehawk Wide Oval AS (W-Speed Rated)
    I put nothing but Michelin Pilot Powers on all my motorcycles and dont mind sticking with that brand but ive heard mixed reviews here
    Michelin Pilot Sport A/S Plus
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Which tire should I run on my Bonnie GXP wheels
    Slower, Lower Delaware
    I'm running Contis DW similar to what BMW put on the M3s. You can look at the reviews on Tirerack. I think they're great for a summer tire. I hear the DWS is good too.
  3. #3 Re: Which tire should I run on my Bonnie GXP wheels
    GTP Level Member
    Pittsburgh
    I have the P Nero's on My DD, and they are Awesome
    2003 SSEi,
  4. #4 Re: Which tire should I run on my Bonnie GXP wheels
    No goodyears, a 260 tread rating????? LOL, They will be gone in 20k miles.
    Personally I would get something that can be rotated on all 4 corners to help with tire life and wear. No directionals.
    Conti DW and DWS are great tires.
    Those P nero's are good for the price.
    Michelins A/S plus are too much money IMO for what your needs are.
    I would try and stay away from a super high performance tire with how much you are driving, they will wear down very fast and you'll be looking at tires very soon.
  5. #5 Re: Which tire should I run on my Bonnie GXP wheels
    Marysville WA
    Ok thanks for the input, im just waiting for my replacement wheel that my wife curbed up pretty bad. So Ultra High Performance" is not gonna suit me well? I do drive a ton and I guess if I had reorganize the priority list it would go like this...
    Life
    Handling
    road noise
    Ill check out the Contis and see what comes up!
  6. #6 Re: Which tire should I run on my Bonnie GXP wheels
    Marysville WA
    So we are thinkin these right?
    Continental ExtremeContact DWS
    I do drive in adverse weather conditions and very rarely in some snow. Also I wasnt sure about the dimensions. I miss the stock tire height for gas mileage but like how much these fill out my well. I would mind a more low pro look but im assuming its best to stay with stock dimensions for the wheels right
  7. #7 Re: Which tire should I run on my Bonnie GXP wheels
    Mar 2012
    NC
    I vote round ones! Square tires just ain't what they used to be.
  8. #8 Re: Which tire should I run on my Bonnie GXP wheels
    I can't even believe the rs-a's are an option. Lmao
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Bridgestone Potenza 970s
    AA and 400 rating. Absolutely a dream
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  10. #10 Re: Which tire should I run on my Bonnie GXP wheels
    May 2008
    Winnipeg, MB
    goodyear tripletread get my vote
    2007 Pontiac Grand Prix
  11. #11 Re: Which tire should I run on my Bonnie GXP wheels
    Marysville WA
    Quote Originally Posted by boosting98 View Post
    The RSAs were the stock tire on the GXP wheels, I think im gonna go with the Contis
  12. #12 Re: Which tire should I run on my Bonnie GXP wheels
    Marysville WA
    So I need the skinny on these tires this is what Les Schwab is trying to sell me, 1085.00 out the door seems kinda pricey and I cant get any specs any insight on these would be sweet thanks
    "Les schwab toyo toureveo"
  13. #13 Re: Which tire should I run on my Bonnie GXP wheels
    Buy tires online for alot cheaper, then take them somewhere to get mounted and balanced. It should be loads cheaper than $1100 bucks.
  14. #14 Re: Which tire should I run on my Bonnie GXP wheels
    A/S + will be kinda the opposite order of what you have listed there.
    How much traction you ask from the tire will play a large role in how long they last.
    Tires that last a long time generally suck at everything but becoming hockey pucks.
  15. #15 Re: Which tire should I run on my Bonnie GXP wheels
    Marysville WA
    Well ive been running numbers and after shipping and mounting costs they seem to even out. The costco near my home will set me up with Michelin*Pilot Sport A/S Plus for 1006.50 out the door. Cant seem to complain about that price. The only thing cheaper that ive found is the Conti DWS but thats at Walmart, and well id rather drive on bald tires then go there for any of my automotive needs.
    matt5112, what im hearing is that I can not have both performance and longevity correct? If this is the case, Id take the Pilots, it seems like every time I mention them to tire dealers they have nothing but good things to say. And today called Discount Tire, Les Schwab, and Costco.
  16. #16 Re: Which tire should I run on my Bonnie GXP wheels
    If you jump into the tire review thread, theres a guy whos used those and some MXM4's.
    The A/S have better wet traction, the MXM4's have better dry traction.
    http://www.grandprixforums.net/offic...ead-62191.html
    I wouldn't touch that firestone tire, my vote goes to the pirelli or the michelin.
    If the Michelin is the least expensive option, go for it.
  17. #17 Re: Which tire should I run on my Bonnie GXP wheels
    Oct 2012
    Winfield, IL
    "Personally I would get something that can be rotated on all 4 corners to help with tire life and wear. No directionals
    I would try and stay away from a super high performance tire with how much you are driving, they will wear down very fast and you'll be looking at tires very soon."
    I also drive a lot of miles each month in my truck and the above response is exactly what I do to extend the life of my tires. New rubber has certainly gotten expensive these days.........
    Oct 2011
    MI
    Before your set on ANY tires check out the Bridgestone RE970AS I've had mine on for a few weeks now and I couldn't be happier with a tire purchase. $992 out the door and they gave me a free Wii this things won't break loose on wet pavement... and if they are saying the new 970s are better then the previous version 960s I expect even better snow performance.
    A few winters ago in my old 04 gtp I had the 960s on the front. I drove through the worst blizzard of the season here in Michigan ...I'm talking several feet of snow on undriven roads and it plowed through like it was nothing.
    Here are my 245/45 18s
    Sent using my Galaxy SIII on Tapatalk
  19. #19 Re: Which tire should I run on my Bonnie GXP wheels
    That is supposed to be a good option as well.
    Oct 2011
    MI
    I read review after review knowing I was going to pay about $1k/set for one of the best tires available. In the end my past experience, price and current impression (just after a few hundres miles) completely agrees with what reviews I've read. :beer:
  1. What tire size do you run on 18" wheels?
    By Jochen in forum Tires & Wheels
    Last Post: 03-13-2015, 11:53 PM
  2. Bought Sport Edition E1 Wheels. Need tire sizes!
    By kking89 in forum Tires & Wheels
    Last Post: 06-06-2012, 11:27 AM
  3. Bonnie GXP wheels on Prix GXP
    By TallassJonG in forum Visual/Body Modifications
    Last Post: 10-17-2009, 11:08 PM
  4. Chrome Wheels/Tire Monitoring System
    By cmw1876 in forum General Tech Discussion
    Last Post: 03-28-2009, 02:11 PM
