Thread: tire size help needed please
Results 1 to 16 of 16
  1. #1 tire size help needed please
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    im wondering if i can run a 245/45ZR17 tire on this rim?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: tire size help needed please
    I live here. TLSheff's Avatar
    A 245/50/17 would be the ideal size on a 17 but if you don't mind being a little off on the speedo you CAN.
    Tire size calculator
    ^^^What I use to compare sizes
  3. #3 Re: tire size help needed please
    Oct 2011
    Michigan
    so wouldnt the speedo being off rape my trans? i was more asking along the lines of if that tire would fit the rim
  4. #4 Re: tire size help needed please
    Ya it should fit. I would guess they are a 17x7 maybe 7.5 so a 245 should fit nicely.
  5. #5 Re: tire size help needed please
    Oct 2011
    Michigan
    wont the shift points be off if the speeds off?
  6. #6 Re: tire size help needed please
    the tire size has nothing to do with trans abuse, only speedo calibration.
    and yes, they'd fit.
  7. #7 Re: tire size help needed please
    Oct 2011
    Michigan
    they could be 6.5 though
  8. #8 Re: tire size help needed please
  9. #9 Re: tire size help needed please
    Oct 2011
    Michigan
    without tire roll?
  10. #10 Re: tire size help needed please
    what are the wheel specs? come back when you find them.
  11. #11 Re: tire size help needed please
    Looks like the 04+ 17x6.5s
  12. #12 Re: tire size help needed please
    Oct 2011
    Michigan
    ^^^^^^^ it is
    stock rims off an 06 GT2
  13. #13 Re: tire size help needed please
    then yeah, it'll fit fine.
    however, you'll have a little less turn in response on hard corners because the tire will need to roll before the contact patch actually grips the road and turns the car. this is only because the wheels are only 6.5" wide.
    any reason you cant run a 225 wide tire?
  14. #14 Re: tire size help needed please
    Oct 2011
    Michigan
    well my friend just bought some Bullitt rims for his winter car and they have some good 245/45ZR17 summer tires on them so hed just give them to me if i wanted them
  15. #15 Re: tire size help needed please
    it won't be terrible, but noticeable compared to a 'correct' sized tire.
  16. #16 Re: tire size help needed please
    Oct 2011
    Michigan
    thanks i wont run them, ill look for some cheap 225s or new rims lol
  1. Help with tire size please!!!!
    By blortz in forum Tires & Wheels
    Last Post: 02-12-2012, 10:34 PM
  2. Tire size help needed!!
    By Pontiacman76 in forum Tires & Wheels
    Last Post: 08-11-2010, 01:57 PM
  3. What size tire can I fit???
    By Bigbm80 in forum Tires & Wheels
    Last Post: 10-06-2009, 10:05 AM
  4. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
  5. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
