Thread: Snow tires
Results 1 to 15 of 15
  1. #1 Snow tires
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    What is a good cheep tire? I will only run them while snow is on the ground and I plan to put them on steel rims. Should I go with a more narrow tire?
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: Snow tires
    Whatever is the cheapest snow tire you can find.
    But really any all season tire can plow through some snow, its all about the driver.
  3. #3 Re: Snow tires
    Nov 2008
    I agree with this but my soon to be wife will be driving it to work everyday (50 miles) and if I can do something to make that easier I'm going to. would you find a narrower tire or would you just run stock sizing?
  4. #4 Re: Snow tires
    Stock size, I see no need to reduce the size. 225/60/16 is not a big tire.
  5. #5 Re: Snow tires
    Jan 1970
    Maquoketa, Iowa
    Stock size is fine, you may want to consider doing the fronts only and just having some good tread on all seasons in the back. I run winterforces' and like them a lot.
    I drive around 500 miles a week year round on a variety of roads, so I can justify spending money on winter tires, I can go a little longer on my regular tires because I'm not using them part of the year. You can drive around in all seasons, but there are times when a real bad snowstorm hits, you're ****ting yourself while only going 30mph 1 hour away from home, wondering what a few hundred bucks could have done. That difference is more like just ****ting yourself while going 45mph.
    It does add comfort, but you're still not invincible, If I were you I would do it without her knowing.
  6. #6 Re: Snow tires
    GTX Level Member cerick08GP's Avatar
    Just to throw out my two cents based on going through decade of Wisconsin winters in my GPs. IMHO GPs handle well in snow, water not so much.
    My suggestion is get an all season tire that is M&S rated. (M&S is mud and snow). That combined with the fact that tread depth is your friend in snow, she will be very well off for at least a couple years. Combine that with proper air pressure, I run 30-31 psi cold and 32-33 psi warm. One last tip, stay away from any LRR tire.
    The TireRack is a great source for tire information and reviews.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: Snow tires
    i liked my general's that i had on my car last year. it was boring to drive, though so im back to all seasons this year.
    a car with too much control is just plain boring.
  8. #8 Re: Snow tires
    Apr 2011
    Vassar, Mi
    M&S doesnt mean anything, I had a 1st gen DSM with 225/35 18's that had M&S stamped on the side and you couldnt drive over 30mph if it snowed a flake. Snow tires all the way around is the way to go on any FWD. The best ones ive had were Goodyear Ultragrip in one size narrower and one size taller than stock. They were a bit pricey though. On the GP I ran General Artics on the front and General all seasons on the back and it wasnt that great. They had really wide tread for a 225 tire and they always tried to get on top of the slush instead of cutting through it. The cheapest snow tire will decimate any all season you can find when it comes to vehicle control in bad weather though. The best snow tire size would be a 215/70 R15, half inch narrower and 1/4" taller than stock. IDK if 15's fit or not though and they dont make a good size tire like that for a 16.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  9. #9 Re: Snow tires
    May 2008
    staten island,NY
    When my GTP used to see snow I used the blizzaks that were from tire rack. Now I have the Sierra with auto 4wd
  10. #10 Re: Snow tires
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    Driver ability is mostly what it comes down to.
    But I spent the money for a cheap set of snow tires prior to last season and have not regretted dropping the $380 for the set of 4 Nitto's. My car is lowered and I still had no problems crawling through descent sized drifts. Seriously, 2 tires would be worth the money!
    02 sedan, top swap
  11. #11 Re: Snow tires
    May 2008
    Winnipeg, MB
    Since we are on the topic of winter tires, what are peoples thoughts on studded tires?
    2007 Pontiac Grand Prix
  12. #12 Re: Snow tires
    Jul 2010
    Coquitlam,BC,Canada
    I have been running Wanli 215/60/16 snow tires for the past 3 years. They are a little on the hard side, not the best in the rain, but kick-ass in the snow. And for $50 each, I can't complain. I don't like the size, but they do the job.
    To those that say that all-seasons can do the job, well, they sort of can. You may be able to plug along, but if/when you have to stop now, you will fail. I have driven all kinds of rigs and tire combos over the years, and until you hammer on the brakes and come to a safe stop, there is no comparison for a snow tire. These tires were on my old Super Coupe, and I needed boost to break the tires loose. I can hold my own in the snow, but when I need to dodge all the other idiots that can't, I need all the help I can get.
    Studs are great if you see icy conditions. I have friends that run them as they head up north a lot. You do get a lot of control out of them, so don't get cocky.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Snow tires
    Nov 2008
    where did you get that price for that kind of tire. Sounds just like what I want
  14. #14 Re: Snow tires
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by kjohnson View Post
    A local tire distributor was overstocked and was blowing them out, thus the smaller size.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Snow tires
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    i bought falken ziex, were around 300$ i believe after i sold my old pair of tires taht were shot.
  1. Snow tires
    By Fubisin in forum Tires & Wheels
    Last Post: 11-07-2009, 05:47 PM
