Thread: will 255/50/16 will fit stock rim on 04
Results 1 to 11 of 11
  1. #1 will 255/50/16 will fit stock rim on 04
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I got a great deal on this tires and I'm a fan of fat tires just wondering if they would fit on the stock rim
  2. #2 Re: will 255/50/16 will fit stock rim on 04
    utah
    youll hate them cuz they will rub like all kinds of hell....ask me how i know
  3. #3 Re: will 255/50/16 will fit stock rim on 04
    SWPA
    Not only are they wider than stock, they are taller.
    245/50/16 would be 25.65" tall
    255/50/16 would be 26.04" tall
  4. #4 Re: will 255/50/16 will fit stock rim on 04
    May 2011
    El paso tx
    I'm running 245/50/16 how bad do they rub? And I can do nothing to run then? And does it affect three ride if they taller?
  5. #5 Re: will 255/50/16 will fit stock rim on 04
    May 2011
    El paso tx
    What's the stock height on the 225/60/16?
  6. #6 Re: will 255/50/16 will fit stock rim on 04
    SWPA
    225/60/16 would be 26.63"
    If you wanted to go wider you'd need 245/55/16 which would be 26.61" tall. I don't even know why I mentioned the 245/50/16
  7. #7 Re: will 255/50/16 will fit stock rim on 04
    The width of the tire would concern me. Are those rims 16x7? Or they still the 6.5?
  8. #8 Re: will 255/50/16 will fit stock rim on 04
    SWPA
    Apparently a 245/55/16 doesn't even exist.
    If you want to go wider, and keep the proper height, your best bet is to go 17's.
  9. #9 Re: will 255/50/16 will fit stock rim on 04
    Omaha, NE
    Quote Originally Posted by boostedcompg View Post
    How do you know?
  10. #10 Re: will 255/50/16 will fit stock rim on 04
    Panama City Beach, FL
    Quote Originally Posted by crazybrownklick View Post
    Knowledge. It flows here.
  11. #11 Re: will 255/50/16 will fit stock rim on 04
    255/45r17, but even thats too short.
    255/50r16 is a DR/ road course slick size.
    You'd want a 16x8 or 16x8.5 wheel.
    Our stock wheels are hardly wide enough for the 225's that are stock.
    Not that wider improves traction unless you're overheating your tire.
    Overheat tire, go wider, better thermal management, more traction.
    Better off investing in a better compound.
  1. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
