Thread: Tire Size
Results 1 to 14 of 14
  1. #1 Tire Size
    SE Level Member jamster00's Avatar
    Apr 2009
    san diego
    Got a great deal on a set of 235/60/16 tires about 90% tread. Will these tires fit on my stock 01 GTP?
  2. #2 Re: Tire Size
    SWPA
    Gonna be a little tall. Stock is 26.7", these are 27.1
  3. #3 Re: Tire Size
    They'll fit. Have that size on my prix. Fills the wheel wells better!
  4. #4 Re: Tire Size
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I run 235/50/18's(Overall Diameter: 27.25 in) and I'm dropped at least 2", you'll be fine... And yes it does fill the wheel wells better
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: Tire Size
    Apr 2009
    san diego
    Will there be some rubbing? When I eye ball it next to the rim on the rear, the shock seem to be really close but I do like to fill in the wheel wells. Thanks for the replies!
  6. #6 Re: Tire Size
    I live here. TLSheff's Avatar
    Quote Originally Posted by jamster00 View Post
    No... it may seem like it would but your not taking into consideration how it actually fit on. Overall height would be 27.1 vs 26.7 leaving a 0.4" difference. Now you have to consider that this is overall, so you will be actually raising the car 0.2" for the bottom and 0.2" for the top so the tire will only be a 0.2" closer to the strut mount. Not 0.4" like it appears. You will be fine, but your speedo will be off a little, don't forget that.
  7. #7 Re: Tire Size
    Apr 2009
    san diego
    Thanks TLSheff! Will be putting on the rubber this weekend!
  8. #8 Re: Tire Size
    Not gonna lie. The rear tires are real close.
  9. #9 Re: Tire Size
    Apr 2009
    san diego
    Hey boosting98,
    Got the flu bug and wasn't able to install them. How close is real close? Are you indicating rub if I have rear passengers? Feelin better and might get them on tomorrow.
  10. #10 Re: Tire Size
    I've been running that size for a year now. Zero signs of rubbing.
    I don't have any. But a small spacer would push em out more if ur concerned.
    What your car will look like:
  11. #11 Re: Tire Size
    Apr 2009
    san diego
    I finally got the tires mounted. This is how close it was. No issues. Thanks all!
  12. #12 Re: Tire Size
    SWPA
    Thats really not close at all. That's 100% normal.
  13. #13 Re: Tire Size
    yeah, that's not very close. that distance also doesnt change ever so youll be fine.
  14. #14 Re: Tire Size
    Good work. Now post pics other then that
  1. Tire Size
    By Hawkins97 in forum Tires & Wheels
    Last Post: 08-07-2010, 01:00 AM
  2. What size tire can I fit???
    By Bigbm80 in forum Tires & Wheels
    Last Post: 10-06-2009, 10:05 AM
  3. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
  4. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  5. is it ok to mix tire size?
    By nemesis in forum Tires & Wheels
    Last Post: 07-20-2008, 12:36 AM
