Thread: Tire recommendation
Results 21 to 40 of 48
  1. #1 Re: Tire recommendation
    Donating User Odi's Avatar
    Chicago South Suburbs
    continentals suck dick unless youre religious about pressure, rotating and having alignment done on a 6 month basis.
  2. #2 Re: Tire recommendation
    Jul 2010
    upstate NY
    For a Ultra Hi Performance all season, the Conti DWS are several notches lower in steering response and cornering stability than the Michelin and Bridgestones below it on the Tirerack list. That doesn't cut it as top of the list in my book.
    For my 05 GT with KYB GR2 struts, I found the Michelin Primacy MXV4 grand touring tires a great match. A bit pricey though. Also, not enough performance for the GTP.
  3. #3 Re: Tire recommendation
    TRZ's
  4. #4 Re: Tire recommendation
    Oct 2011
    michigan
    Sometimes there is such a thing as too many choices. lol
  5. #5 Re: Tire recommendation
    Quote Originally Posted by chevy468 View Post
    thats when you go with the cheapest
  6. #6 Re: Tire recommendation
    Donating Users Burgundyman's Avatar
    I bought a set of four Michelin Tires PRIMACY MXV4 225/60R16 98H...Tires received excellent reviews in Consumer Report. I also read reviews on TireRack.com where most folks really liked them...Performs well in both dry and wet conditions.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  7. #7 Re: Tire recommendation
    GTP Level Member
    Nov 2011
    Kansas
    I just put Bridgestone Turenza Serenity's on my GP and they are AMAZING!!! Super smooth ride, high tread life, asymmetrical design. They do great on dry and wet roads and throw rain like no ones business. I guess I will find out about snow here eventually. They arent however the cheapest option out there. They are considered ultra high performance grand touring tires. Acura TL's and other cars of the like come stock with them.
  8. #8 Re: Tire recommendation
    Jul 2011
    NW Ohio, USA
    Gotta put my vote out for General Tire Altimax HP's. Just got a set installed on the GP and I'm loving them so far. Quiet as I've ever heard a tire to be and from what I've experienced so far the traction can't be beat. I've even tried to get them to slide on wet roads (i.e. really hard braking on wet roads) and I haven't got them to slide yet. Really great tire in my opinion, and I got them for right at $100 and change per tire installed.
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  9. #9 Re: Tire recommendation
    Out West
    Quote Originally Posted by 98L36 View Post
    Wait till you hit a set of corners and watch your car do the macarena.
  10. #10 Re: Tire recommendation
  11. #11 Re: Tire recommendation
    Jul 2011
    NW Ohio, USA
    I'm not that stupid, I don't try to get them to slide on corners...I've tried it on empty roads from like 35, I'm not stupid enough to try it at 60. I'd expect almost any tire to slide at 60 MPH on wet roads.
  12. #12 Re: Tire recommendation
    Out West
    235/40/18 do however.
  13. #13 Re: Tire recommendation
  14. #14 Re: Tire recommendation
    Out West
    Not for a stock wheel
  15. #15 Re: Tire recommendation
    not for an 18 either. you should have a 50 series on there, not 40. your tire is too short meaning you dont have to roll the bead before the tread catches.
  16. #16 Re: Tire recommendation
    GTP Level Member
    Oct 2011
    Raleigh, NC
    What is a good pressure ? stock tires 225 60 16 on a 97 gtp stock vehicle
    1997 Red GTP 182000 miles stock
  17. #17 Re: Tire recommendation
    Out West
    50 series didn't fit in the front fenders, and rubbed severely in the rear.
  18. #18 Re: Tire recommendation
  19. #19 Re: Tire recommendation
    245/45/18 is THE correct size. if you go down in tread width you go up in height and vice versa. you went down in both meaning your tires are shorter than stock. you have wheel gap, son.
  20. #20 Re: Tire recommendation
    Out West
    THE correct size didn't work for me as i'm running a +18 wheel.
  1. amp recommendation
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 07:47 AM
  2. Oil & filter brand recommendation?
    By nFavor in forum 5.3L V8 (LS4)
    Last Post: 03-15-2010, 08:50 PM
  3. Exhaust recommendation
    By amwhitey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2010, 12:41 AM
  4. Need Recommendation
    By J GTP in forum Audio, Security & Visual Electronics
    Last Post: 05-11-2009, 10:14 PM
  5. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
