Will stock g35 rims fit gp?
They are 5x114.3, which will work.
But the rim size and offsets are like this:
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
I was wondering if that would work, or would the wheels stick out to far?
http://carphotos.cardomain.com/ride_...0588_large.jpg
These are on the forum have been posted before. Them are 19s off of a M45
Whoever's car that is...it needs a debadge HORRIBLY.
The offset also depends on the size of the rim. Someone on here is running 18x9's with a +30 perfectly fine. With the smaller 17x8/7.5 you should be fine running a +30.
The Pregen 5 spoke rims are 16x7 with a +24 offset iirc? And they work fine. I think you will be more then fine.
Mmmmmm 19's are so perfect
No they wont work unless you bore out the hub bore on the wheels or run some 10mm spacers.
Infiniti/nissan hubs are way smaller then ours.
as far as the offsets. Your fine,
