Thread: Will these Fit??
Results 1 to 7 of 7
  1. #1 Will these Fit??
    SE Level Member jjm3000's Avatar
    Jul 2008
    Canada
    Buy 19x8.5 rims ruff racing r280 wheels Chrome color. ruff racing r280 19x8.5 chrome wheels at WheelsNext.com
    Tires 245/40/19
    Rim Size 19 x 8.5 with 35 offset
    Anyone run these on a grand prix before?
    SSC Springs, 3.5 Pulley, Overkill PCM Tune, Thrasher CAI with K&N, 180 TSAT, Custom front to back 2.5" Exhaust with Magnaflow mufflers, GMPP STB front and rear, GMPP Sway Bars front and rear and GMPP Rear Trailing Arms.
  2. #2 Re: Will these Fit??
    you need bolt pattern 5x115 or you can run 5x114.3
  3. #3 Re: Will these Fit??
    Grand Island, Nebraska
    those look sweet though if you can get the bolt pattern.
  4. #4 Re: Will these Fit??
    Jul 2008
    Canada
    Ok a different website list these as 114.3 so they should be ok right? What about the offset is +35 ok??
    RUFF RACING WHEELS R280 CHROME - Wheels and Rims from Performance Plus Tire
  5. #5 Re: Will these Fit??
    yes, those will fit. you're probably going to have to roll your fenders.
    i ran a set of wheels with the exact same specs and tires, except mine had a +45mm offset. they rubbed and so will yours.
  6. #6 Re: Will these Fit??
    Jul 2008
    Canada
    Alright guys new question for you:
    What if I went with a 20x 8.5 wheel with a + 45 offset. Do I still have to roll my fenders?
  7. #7 Re: Will these Fit??
    that's gonna be pretty similar to the 19s you posted. either way it really depends on the tire you run, your alignment settings, and the wear on your suspension. who knows, it might not rub. i was just trying to let you know its highly possible.
fit
