Thread: Lowered...20s?
Results 1 to 10 of 10
  1. #1 Lowered...20s?
    SE Level Member pghtattooer's Avatar
    pittsburgh,pa
    I have a 06 gp I plan on dropping it with the ssc springs am I able to fit 20s or are 18/19s better?
  2. #2 Re: Lowered...20s?
    May 2008
    Winnipeg, MB
    Mr.Angry.GTP over on gpona.com has done it with 20's and looks real good
    2007 Pontiac Grand Prix
  3. #3 Re: Lowered...20s?
    pittsburgh,pa
    Do u have a link to a pic of his?
  4. #4 Re: Lowered...20s?
    May 2008
    Winnipeg, MB
    also DrunkieTheBear on here, use the search feature
  5. #5 Re: Lowered...20s?
    20's are too big i think.
    18's would be better and you will prolly have to roll your fenders depending on the wheels you get.
  6. #6 Re: Lowered...20s?
    Jul 2008
    sumter,south carolina
    this may give u a lil insight also...
    http://www.grandprixforums.net/want-...ere-28165.html
    02 GTP with mods 05 GP for DD
  7. #7 Re: Lowered...20s?
    May 2008
    Winnipeg, MB
    tirerack.com allows you to order 20's so its pretty safe they work without rolling the fenders
  8. #8 Re: Lowered...20s?
    Jul 2008
    Quote Originally Posted by tod1d View Post
    yea but hes going with a 1.7 inch drop.
  9. #9 Re: Lowered...20s?
    jesus christ...
    20s will not be any different than 18s or 13s for that matter unless you run a tire size that is TALLER THAN STOCK. if you keep the same overall diameter of the tire youll be fine. however, there is more than just wheel diameter that matters. wheel width, wheel offset, and tire size also affect rubbing issues.
    WHAT WHEELS DO YOU WANT TO RUN AND WHAT TIRES? we need ALL of the specs to tell you anything useful. otherwise our best answer is 'maybe?'.
  10. #10 Re: Lowered...20s?
    pittsburgh,pa
    thanks for all the help and insight i got it taken care of. thanks again
  1. So I lowered my car today...
    By joshua_arndt in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2011, 11:07 AM
  2. Car finally lowered!
    By Lsick7 in forum Off Topic Discussion
    Last Post: 04-05-2010, 08:17 PM
  3. Lowered & New Wheels!
    By KawaFord in forum Off Topic Discussion
    Last Post: 01-08-2010, 04:29 PM
  4. Needs the car to be lowered?
    By ricez in forum Tires & Wheels
    Last Post: 08-19-2008, 07:17 AM
