the T rating should be fine as far as speed goes, just if you want more steering response, the H will benefit there.... both due to tread compound differences, and sidewall construction, which ultimately let you run a higher PSI in the tires.
there might me a minimal ammount of tradeoff with the H in winter traction, because of the slightly firmer tread compound, but not sure if you'd notice much.
