do 245/50/r17 fit on the stock rim of a 06. not going to lower or anything just want a bigger wider tire thanks.
ok i just did that and this is what i came up with, it says the width range of the 245 is 7-8.5 and im pretty sure the stock rim is 6.5 wide.....
Stock Tire - 225/55R17
section width-8.85
rim width range 6-8
diameter difference
Tire 1 - 245/50R17
9.64
7-8.5
0.38%
the stock rim is 6.5" or 7" wide, which means you can run a 245 series tire MAX. its been done many times, but its really up to you if you want to pay for the extra bit of thread width.
