Thread: found some wheels just wantin to know if theyll fit
Results 1 to 14 of 14
  1. #1 found some wheels just wantin to know if theyll fit
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    moda 18x8, bolt pattern is 5x115, offset +40, backspace is 6.10 in. and tires are 245/45/18. if it matters im on eibachs. pretty sure theyll fit but yeah. thanks in advance guys
  2. #2 Re: found some wheels just wantin to know if theyll fit
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    tirerack.com is your best friend i think they have those rims and they got good prices too
  3. #3 Re: found some wheels just wantin to know if theyll fit
    Troy OH
    everything sounds about right. is it lowered at all?
  4. #4 Re: found some wheels just wantin to know if theyll fit
    offset = backspacing, just a different measurement.
    they should fit and probably wont rub unless you put 255s or bigger tires on it.
  5. #5 Re: found some wheels just wantin to know if theyll fit
    Nov 2009
    Michigantown, IN
    im prolly sittin at least 1.5in lower than stock. yeah i did find them at tirerack. heres the address to a pic of them. http://www.tirerack.com/images/wheel...bsml_ci3_l.jpg
  6. #6 Re: found some wheels just wantin to know if theyll fit
    Troy OH
    should be good. there's guys that have 19s and 20s or bigger. they look good too
  7. #7 Re: found some wheels just wantin to know if theyll fit
    the size of the wheel diameter doesnt matter, its the overall tire diameter that matters. also the width and offset of the wheel. all of these will affect if the wheels will rub. if you run the same size tire as the stock overall diameter then youll have no problems.
  8. #8 Re: found some wheels just wantin to know if theyll fit
    Nov 2009
    A place called Hope.
    Nice looking wheels. What tires are you going to run?
  9. #9 Re: found some wheels just wantin to know if theyll fit
    Nov 2009
    Michigantown, IN
    idk prolly nitto. then again i dont really race much. prolly just a good all around tire. i have friends that work at wheel shops so i might get a deal.
  10. #10 Re: found some wheels just wantin to know if theyll fit
    get a nice sticky all season tire that is a little wider (245 or 255 wide) and youll be better off. youll be able to run them for two or three seasons and they will handle a lot better in the rain than a summer only tire will.
  11. #11 Re: found some wheels just wantin to know if theyll fit
    Nov 2009
    Michigantown, IN
    k update. the moda rims for my car sold out but i found the same ones for a 2000 maxima. the only difference is the 35mm offset and the 5x114.5 bolt pattern. everything else is the same. any probs with these?
  12. #12 Re: found some wheels just wantin to know if theyll fit
  13. #13 Re: found some wheels just wantin to know if theyll fit
    Nov 2009
    Michigantown, IN
    thanks bio. i just hate buying stuff online only to find out they dont work. i prefer people to people sales...lol at least then i can return it locally.
  14. #14 Re: found some wheels just wantin to know if theyll fit
    Donating User Odi's Avatar
    Chicago South Suburbs
    yeah, both rims you posted should work just fine even with the eibach drop.
  1. Found my First GTP?!?
    By NateDogg713 in forum Off Topic Discussion
    Last Post: 07-19-2009, 10:45 AM
  2. Found IT !
    By mickey t in forum Introductions/Noob Questions
    Last Post: 06-08-2009, 07:48 PM
  3. Old pic i found
    Last Post: 12-24-2008, 11:18 PM
  4. Found This Joke. Also Found It Amusing.
    Last Post: 12-05-2008, 04:25 AM
