moda 18x8, bolt pattern is 5x115, offset +40, backspace is 6.10 in. and tires are 245/45/18. if it matters im on eibachs. pretty sure theyll fit but yeah. thanks in advance guys
im prolly sittin at least 1.5in lower than stock. yeah i did find them at tirerack. heres the address to a pic of them. http://www.tirerack.com/images/wheel...bsml_ci3_l.jpg
the size of the wheel diameter doesnt matter, its the overall tire diameter that matters. also the width and offset of the wheel. all of these will affect if the wheels will rub. if you run the same size tire as the stock overall diameter then youll have no problems.
Nice looking wheels. What tires are you going to run?
idk prolly nitto. then again i dont really race much. prolly just a good all around tire. i have friends that work at wheel shops so i might get a deal.
get a nice sticky all season tire that is a little wider (245 or 255 wide) and youll be better off. youll be able to run them for two or three seasons and they will handle a lot better in the rain than a summer only tire will.
k update. the moda rims for my car sold out but i found the same ones for a 2000 maxima. the only difference is the 35mm offset and the 5x114.5 bolt pattern. everything else is the same. any probs with these?
thanks bio. i just hate buying stuff online only to find out they dont work. i prefer people to people sales...lol at least then i can return it locally.
yeah, both rims you posted should work just fine even with the eibach drop.
