Thread: rim width/offset
Results 1 to 20 of 23
  1. #1 rim width/offset
    Joliet, IL
    hey i know there are alot of these posts but i couldnt find one for this particular width/offset.....i found some 17x8 bullitts with a +30mm offset...can i run my 255 45 17 nittos on these with eibachs with rolled fenders and not worry about it?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: rim width/offset
    Donating User Odi's Avatar
    Chicago South Suburbs
    If you roll fenders you shouldnt have to worry about rubbing.
  3. #3 Re: rim width/offset
    Quote Originally Posted by MiriV View Post
    not true. with a low or high enough offset youll rub no matter what you do to the fenders.
    how bad were you rubbing with your +24mm wheels? i would THINK that you could pull these off without worrying too much, but youll never know until you try it.
  4. #4 Re: rim width/offset
    Joliet, IL
    i wasnt rubbing bad on a +26mm 17x9.....these are +30 17x8 wouldnt the inch loss in width combined with the higher offset work....my original bullits were 17x8 +24mm offset and they didnt rub (not fenderolled either) but i was running 245 45 17's and i will now be running 255 45 17's i want my rims to tuck close so that my fenders being rolled isnt pointless....
    00 Silvermist GTP
  5. #5 Re: rim width/offset
    i think you should be okay, but again you wont know until you try.
  6. #6 Re: rim width/offset
    Joliet, IL
    what about a 17x9 with a +45mm offset would that rub up front while turning?
    00 Silvermist GTP
  7. #7 Re: rim width/offset
  8. #8 Re: rim width/offset
    Joliet, IL
    too many questions. too little trying it out.
    well i dont wanna spend money on rims im gonna have to resell....how much of a difference is a 17x9 w/ +45mm offset ... as opposed to the OP rim? but i think ill just get the +45mm even though im not sure it will work right....
    00 Silvermist GTP
  9. #9 Re: rim width/offset
    not sure if with a 9" wide wheel that itll rub on the struts then with that high of an offset. the wider the wheels the lower the offset you have to go to get them to fit without rubbing the struts.
  10. #10 Re: rim width/offset
    On a 30 offset you should be fine, you answered your own question: new wheel has a better offset (means, sits more inside the fender) and is not as wide, so you should be fine.
  11. #11 Re: rim width/offset
  12. #12 Re: rim width/offset
    Joliet, IL
    +30mm offset is still pushing it pretty far.
    tis why i got +38mm offset instead
    00 Silvermist GTP
  13. #13 Re: rim width/offset
    ^post pics damnit!
  14. #14 Re: rim width/offset
    Well i got the good/bad luck of getting Bullits (i know you hate them, but this is my only temporary budget option) almost for free and theyre from a 02 stang... So +30 offset will push me pretty bad, but i think im gonna be fine with rolled fenders, eibach springs and kyb shocks.
  15. #15 Re: rim width/offset
    you should be okay with the fender work. i know i had mine rolled all around the car to run my 19s without rubbing.
  16. #16 Re: rim width/offset
    Joliet, IL
    as long as they are 17x8's youll be fine...im running 17x9's with a +38mm offset on eibachs and BARELY tucking the 255 nittos im running....
    00 Silvermist GTP
  17. #17 Re: rim width/offset
    If I recall correctly, they are 8's, if not then ill just rub but oh well... Its all about HELLA FLUSH!
  18. #18 Re: rim width/offset
    the only place ive heard "hella flush" is the subaru forums. wow. i like hella flush though, it looks tits.
  19. #19 Re: rim width/offset
    Joliet, IL
    yessir
    00 Silvermist GTP
  20. #20 Re: rim width/offset
    With so much fender so easy to get at why not "pull" the fenders like the euros and tuner cars do and keep the cobras boostjunkie3?
    My dream would be rocking some HRE monoblocks on my red coupe on some intense coilovers. Few on Clubgp have been building coilovers also.
  1. P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    By STOCKTA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 08:36 AM
  2. Offset
    By gpgt04 in forum Tires & Wheels
    Last Post: 07-18-2009, 12:30 PM
  3. Offset question, 96 gtp
    By bud6770 in forum Tires & Wheels
    Last Post: 05-11-2009, 12:36 PM
  4. Offset and Backspacing?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-04-2009, 12:42 PM
  5. Rim Width?
    By drivehard in forum 5.3L V8 (LS4)
    Last Post: 03-10-2009, 12:13 PM
