Thread: Painting Your Rims. Help!
Results 1 to 10 of 10
  1. #1 Painting Your Rims. Help!
    Apr 2009
    Nassau County, New York
    hey guys, hypothetically speaking im not sure if i want to do it or not but, whats the best way to paint your rims if you were to do it yourself. what would i need, how much would it cost, how long would it take etc. i dont just want to take a spray paint can and make it look bad. i would like to try to make it as professional as possible. please help. thanks
  2. #2 Re: Painting Your Rims. Help!
    Joliet, IL
    sand down original finish...primer.....paint with your choice of paint (duplicolor makes wheel paint), clear coat....when its all dry 2000 grit wet sand it and then use 3M rubbing compound with a mother powerball (gets all sanding lines out to make it a glass like finish) then finish it off with a polish on the powerball...and finally wax the shyt out of them....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: Painting Your Rims. Help!
    Apr 2009
    awesome thanks. how many coats? if anyone has pics post them
  4. #4 Re: Painting Your Rims. Help!
    Joliet, IL
    Quote Originally Posted by shape275 View Post
    id do 3 coats of each...first one light second one medium last heavy
    00 Silvermist GTP
  5. #5 Re: Painting Your Rims. Help!
    Charles City, IA
    Powder coat them.
    SMGPFC Two Nipple General
  6. #6 Re: Painting Your Rims. Help!
    GT Level Member Perry125's Avatar
    maryland
  7. #7 Re: Painting Your Rims. Help!
    May 2008
    staten island,NY
    i would suggest a self etching primer
  8. #8 Re: Painting Your Rims. Help!
    Apr 2009
    thanks guys. does anyone know the cost of what ill need?
  9. #9 Re: Painting Your Rims. Help!
    Joliet, IL
    can of clear, can of paint 12$ sandpaper and other prep supplies...20$ at most...it will cost you around 40-50$ to do it right....i would go with the powdercoat option over all tho as stated above....more money but will last/look alot better...
    00 Silvermist GTP
  10. #10 Re: Painting Your Rims. Help!
    Apr 2009
    alright i really appreciate it
  1. dash painting
    By Couch in forum Visual/Body Modifications
    Last Post: 06-29-2009, 01:04 AM
  2. Re-Painting my KYB AGX
    By Quicklynx in forum Visual/Body Modifications
    Last Post: 05-13-2009, 01:56 AM
  3. Painting stock rims
    By Dagujugrandprix08 in forum Tires & Wheels
    Last Post: 03-09-2009, 06:31 AM
  4. Painting Pricing
    By TCO in forum Visual/Body Modifications
    Last Post: 02-08-2009, 12:30 PM
  5. painting
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 02-12-2008, 04:53 AM
