Thread: What size tires/rims if i want to upgrade from 16 -> 18.
Results 1 to 5 of 5
  1. #1 What size tires/rims if i want to upgrade from 16 -> 18.
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I want to get a set of 18" rims, and i have no idea how to convert the tire size, local garages are of no help, they tell me i can only go 17". i currently have 16's. could anyone help?
  2. #2 Re: What size tires/rims if i want to upgrade from 16 -> 18.
    Ohio
    My friend had 245/45/r18s on his wheels with no problems. he wasnt lowered though. Others will be of more help to you in this category than i but i know u can run those just fine.
    00 GTP demodded and forsale
  3. #3 Re: What size tires/rims if i want to upgrade from 16 -> 18.
    Banned - Busted For Scamming
    Feb 2009
    245/45/18 is pretty much the same diameter, so your speedo wont be off.
  4. #4 Re: What size tires/rims if i want to upgrade from 16 -> 18.
    245/45/18 is the most common that you will see. i would have been different and ran wider tires, but thats just me.
  5. #5 Re: What size tires/rims if i want to upgrade from 16 -> 18.
    SE Level Member og512's Avatar
    Arlington Heights, IL (NW Suburb of Chicago)
    i'm running 245/45/18's with no problem or change in speedo
  1. what size tires?
    By superv6 in forum General Tech Discussion
    Last Post: 10-12-2009, 11:56 PM
  2. New Rims/Tires
    By MuTaLiZeD in forum Tires & Wheels
    Last Post: 04-28-2009, 11:43 AM
  3. Max Size Tires?
    By N3p in forum Tires & Wheels
    Last Post: 04-30-2008, 12:54 AM
