Thread: 20" inch tire size
Results 1 to 10 of 10
  1. #1 Re: 20" inch tire size
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    i have 245/35/20 on mine but i have a 2000 gtp, but my friend has 245/30/22 on his gt/se and he never scrubs but rim offset and width has to be correct or you can scrub on 18s
  2. #2 Re: 20" inch tire size
    Jan 2009
    edgard
    man i have 255/30/24 and i got just a lil rub when i hit big bumps
  3. #3 Re: 20" inch tire size
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    Quote Originally Posted by mastertookie51 View Post
    Wow, that's more than 3.25" larger outer diameter than stock wheel/tire combo. Your GP can't be happy with you. Speedo at 60mph has to be off by like 10mph. Trans, brakes/abs, etc. all have to be off and under much added strain. Heavier wheels is one thing, but going that far out of specs isn't really something I'd ever advise. I don't know that they make a tire the correct size to maintain the correct diameter even. It would literally be nothing, but a solid rubber band around the rim. It would have to be something crazy like a 245/20-24 or 245/15-24.
    Yes, I know it's doubtful you are going for any kind of performance with a set up like that. The most recommended size tire for a GP on 20s is going to be 245/35-20. As others stated, the 255/35-20s the original post asked about are very close to stock diameter and it would depend on offset, etc. Should be ok in most cases though.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  1. Tire size 235/55?
    By RedLedbetter in forum Tires & Wheels
    Last Post: 05-09-2009, 02:14 PM
  2. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
  3. Stock crome 16" wheel...what size tire?
    By Boosted02GTP in forum Tires & Wheels
    Last Post: 03-04-2009, 09:57 PM
  4. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  5. is it ok to mix tire size?
    By nemesis in forum Tires & Wheels
    Last Post: 07-20-2008, 12:36 AM
