Thread: will these wheels fit
Results 1 to 5 of 5
  1. #1 will these wheels fit
    SE Level Member blazer2002's Avatar
    Fremont
    would a set of wheel with these specs bolt up to my 2000 gp gtp and would i have any issues with them like rubbing
    Size- 18 "x 9 "
    Bolt Pattern- 5x114.3
    Offset- +10mm
    Weight - 24.8 lbs
  2. #2 Re: will these wheels fit
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    It should be a 30mm to 40mm offset is what I have been told. that 10 might not be enough?? Are they new, or could you test fit one?
  3. #3 Re: will these wheels fit
    they gonna stick out way 2 far for anybodies liking!
  4. #4 Re: will these wheels fit
    those will not fit. the offset is WAY off. the max you can get away with on a 9" wide rim is around a +35 offset. even then youll have to roll the fenders.
    find a different wheel.
  5. #5 Re: will these wheels fit
    Fremont
    thanks for the advice i wont be getting those rims
  1. what wheels can i use?
    By sweden in forum Tires & Wheels
    Last Post: 02-10-2009, 07:36 AM
  2. What about these wheels?
    By 98GT3800 in forum Off Topic Discussion
    Last Post: 10-16-2008, 09:46 PM
  3. New Wheels
    By SLO-6 in forum Tires & Wheels
    Last Post: 08-24-2008, 11:21 PM
  4. new wheels
    By Zach3800 in forum Visual/Body Modifications
    Last Post: 05-13-2008, 11:04 PM
