Thread: Affordable Wheel options on 06 gxp
Results 1 to 6 of 6
  1. #1 Affordable Wheel options on 06 gxp
    Jul 2017
    Christiansburg,VA
    Looking for a fairly inexpensive option for replacing my wheels on my gxp.
    Clearcoat is in bad shape even after a good polish on 3 wheels and when I bought car used, it had one new wheel.
    Problem with the new wheel is that it's chrome plated. I have a price to have them powder coated at $80 each but they said chrome won't powder coat well so one of the three tires I really don't want to powder coat.
    Any other decently priced wheel options? I'd rather just sell all 4 of these and go another route.
    I also bought car with 18x7's all the way around.
  2. #2 Re: Affordable Wheel options on 06 gxp
    Oct 2011
    Toledo, OH
    Chrome is too smooth for powdercoat to adhere to but a good sanding or bead blasting will solve that problem. The polished 3 with clearcoat will need to be completely stripped of any finish first as powder only sticks to electrically conductive surfaces.
    7"
  3. #3 Re: Affordable Wheel options on 06 gxp
    Nov 2012
    Madison
  4. #4 Re: Affordable Wheel options on 06 gxp
    Kemmerer, Wyoming
    I picked up a set of 06 Dodge Charger wheels for 150 bucks. same bolt pattern, hub bore is 1mm bigger on the charger wheels and the offset is like +28, so a more aggressive look. 18x7.5 size.
  5. #5 Re: Affordable Wheel options on 06 gxp
    Jul 2017
    Christiansburg,VA
    Thanks for some great options everybody. If all the aftermarkets I've looked at, I like those hyper blacks best. I am leaning towards stripping the three wheels that have bad clear and then polish/reclear them but if charger wheels really fit, I might go that route if I can find a set for 150. That'd be awesome!!!
  6. #6 Re: Affordable Wheel options on 06 gxp
    Sep 2017
    Winneconne, WI
    Still looking for wheel options on my "new" 2008 GXP. I do not want to run the stock chrome rims in winter salt conditions. A friend told me the earlier GTP rims that are 17" will work. Any other suggestions if I don't find a set of those?
  1. Wheel/Tire options
    By TateBongard in forum Tires & Wheels
    Last Post: 01-31-2015, 09:47 AM
  2. New wheel options??
    By Alix0r in forum Tires & Wheels
    Last Post: 10-15-2014, 02:44 AM
  3. 67 wheel options
    By hlbones in forum Tires & Wheels
    Last Post: 08-06-2012, 10:14 PM
  4. steering wheel control options
    By christopher8911 in forum Audio, Security & Visual Electronics
    Last Post: 06-08-2010, 08:35 PM
  5. wheel options
    By M.$tErNeR in forum Tires & Wheels
    Last Post: 05-21-2010, 05:39 PM
