Quote Originally Posted by WickedGoat View Post
Here is Bio's thread from 2010, as stickied...
Everyone has questions on what wheels they can and cannot run. The first thing you need to think of when buying wheels is WHAT TIRE DO I WANT TO RUN? This will help you decide on what you can run for wheel specs. Most of the people like to go with a little wider tire for that performance look and a slightly lower offset wheel than stock. this is usually the best combo for fitment. Normally a little better tire than stock will be a 235 or 245 series wide since the stock tire is a 225. On most wheels you'd be able to run a 255 wide tire and still get away with it. however, the lower you go and the more aggressive of fitment you run with the wheels, the harder it is to fit everything without rubbing. The stock wheels have an offset of +52mm and you can tell they sit into the wheel well fairly far. This means we have a bit of room to move out with a lower offset wheel for that aggressive look we all want. I would normally say that the BEST offset (so long as its not too wide and not that big of wheel) is in the area of +38mm give or take a few millimeters in either direction.
Tire sizing
The stock tire size is 225/60/16. Here are the sizes for wheels that have the same overall diameter and that are most typical for people to run:
235/55/17
245/50/17
235/50/18
245/45/18
235/45/19
245/40/19
245/40/20
245/35/20
I was hoping that a 235/50 would be OK, moreso for aesthetics. The Moog springs kinda pissed me off because the car sits higher than I would like it. I guess if I need to run the 245/45's I will, but I was just going by what has been posted and I assumed proven to work. I am more of a reader than a poster on car forums. I try to search and find answers from the guys that have been there and done it.
Some of that info is wrong. Stock diameter is 26.7". The 235/55/17 is even wrong as it is close to 27.1". The correct size 17 is 225/55/17, or 245/50/17.
Quote Originally Posted by Travisgt2 View Post
I'm running a 245/50zr16 for the fronts and 225/60r16 rear. Fronts don't rub but I'm stock height and only 16s
245/50/16 is 1" shorter than stock.
