Thread: Wheel spacers?
Results 1 to 8 of 8
  1. #1 Wheel spacers?
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    I'm looking at getting a set of wheel spacers to get my wheels to poke a little more. These are the right specs as far as I can tell (bolt pattern and center bore is right), but are these a good brand? I don't wanna cheap out, lol.
    http://www.amazon.com/Centric-Spacer.../dp/B00IHRBM3W
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: Wheel spacers?
    anything you find is going to be relatively the same unless you make sure you go with a GOOD reputable brand.
  3. #3 Re: Wheel spacers?
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    I was thinking about wheel spacers long ago, a spacer is fine (1/4" or so) that still retains factory studs. I don't think I would go with something that utilizes its own studs stamped into a chunk of aluminum, but that's just my $.02
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  4. #4 Re: Wheel spacers?
    Apr 2015
    Illinois
    What would a good, reputable brand be? And these studs aren't stamped, they run through the back
  5. #5 Re: Wheel spacers?
  6. #6 Re: Wheel spacers?
    Nov 2011
    NY
    those are good as are these...
    http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Adapters-Wheel-Spacers.asp?b=all#axzz3q5H5OO7M
  7. #7 Re: Wheel spacers?
    Jan 2009
    Tallahassee, FL
    I used to run a pair from these guys. Quality product.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: Wheel spacers?
    Oct 2011
    Toledo, OH
    Thanks Bio, that's where I got mine and couldn't remember the site when I was posting in his other thread.
    Cadillac CTS 25mm ones.
    7"
  1. Wheel Spacers
    By snj111795 in forum Wanted To Buy - Parts
    Last Post: 07-06-2015, 11:06 AM
  2. Re: Wheel spacers
    By widetrack2000 in forum Tires & Wheels
    Last Post: 04-27-2014, 09:14 AM
  3. looking for wheel spacers
    By dezebe1 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2013, 09:06 PM
  4. wheel spacers...
    By bandits grand prix in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2012, 09:19 AM
  5. Wheel spacers?
    By PolishedandWaxed in forum Tires & Wheels
    Last Post: 02-15-2010, 07:17 PM
