Thread: Rave: valve job
Results 1 to 8 of 8
  1. #1 Rave: valve job
    Grand Island, Nebraska
    So my stepdad knows a guy that works in a performance shop that build big blocks/fast small blocks/ ect. Well anyway I needed a valve job so he came over and took them off to his shop. I got the bill: less than $40 for a valve job! and he even cleaned the gasket surfaces and possibly put them in a hot/solvent tank. I should have had him mill them for a bigger cam since he was so dang cheap. /rave
  2. #2 Re: Rave: valve job
    MO
    Rant?
    <brandonl2000> LMAO D!!
  3. #3 Re: Rave: valve job
    Topeka, KS
    Wow that's cheap.
  4. #4 Re: Rave: valve job
    GTP Level Member AjL227's Avatar
    IL
    Always better to hear someone rave, instead of rant. Are those L67 heads? They look good.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  5. #5 Re: Rave: valve job
    Wtf is wrong with that one head? It looks like he missed a spot.
  6. #6 Re: Rave: valve job
    Sorry about the rave thing, we have a rant/rave section on my local forum.
    Quote Originally Posted by slick2500 View Post
    Are you talking about inside the port? that was the farthest my dremel could reach inside haha. I ported these myself.
    And yes they are L67 heads.
  7. #7 Re: Rave: valve job
    You know you can get extensions for dremmels at menards home depot and lowes right? Just a heads up. Those do look nice tho. Wish I had a good shop in ND to get work done.
  8. #8 Re: Rave: valve job
    thanks. If i dont start the swap this weekend i might go pick some up. Its only a little bit in the intake port though, I got all of the exhaust covered, which is where there is the most improvement.
    Edit: Actually, probably not. Im not gonna risk nicking the valve seat. Because I know I will.
  1. Rave: VTEC
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 05-14-2011, 11:20 AM
  2. EGR valve
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2010, 10:07 PM
  3. will car run without EGR Valve
    By kingsmurf in forum General Tech Discussion
    Last Post: 06-04-2010, 08:14 PM
  4. EGR Valve! What does it do?
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2009, 09:40 PM
  5. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
