Thread: The BS that is Pontiac's ABS Sensor.
Results 1 to 20 of 27
  1. #1 The BS that is Pontiac's ABS Sensor.
    florida
    I have a '99 Pontiac Grand Prix GT, and I'm sure that most people know of the problem with replacing the ABS sensor. I have one that is broken on the front wheel of the drivers side, and to replace that little sensor, I have to replace the entire hub, which would run me for about $500.
    TOTAL BULL. The sensor isn't expensive to fix, but to replace the entire wheel bearing hub? This is on Pontiac, whose looking to make money. No wonder why they went under.
    Imports>Muscle.
    At least a Beamer is made with quality.
  2. #2 Re: The BS that is Pontiac's ABS Sensor.
    Charles City, IA
    Um you can get a good hub for under $200. And put it in 20 min.
    SMGPFC Two Nipple General
  3. #3 Re: The BS that is Pontiac's ABS Sensor.
    florida
    Already checked with GM; you can't replace the ABS without replacing the entire wheel bearing. And that runs anyone, including my father, a mechanic, 500.
  4. #4 Re: The BS that is Pontiac's ABS Sensor.
    Charles City, IA
    I am a mechanic. rockauto.com get a hub assembly.
  5. #5 Re: The BS that is Pontiac's ABS Sensor.
    Quote Originally Posted by Firebird789 View Post
    E36 = failed water pump impeller, failed t-stat housing, failed rad neck, failed fan blades.
    Thank you, come again.
    All manufacturers make ****ty cars.
    Do you HONESTLY think super cars are perfect? If so... I dare you to look into the service records on the things...
  6. #6 Re: The BS that is Pontiac's ABS Sensor.
    florida
    I meant quality as in driving wise; handling and such.
    No car is MADE perfect; every make has flaws, but a few HANDLE nearly perfect.
  7. #7 Re: The BS that is Pontiac's ABS Sensor.
    Thats not production and part quality as you mentioned but merely the design of the car...
    Here we drive in staight lines, in europe, they actually have to make gradual turns.
  8. #8 Re: The BS that is Pontiac's ABS Sensor.
    Charles City, IA
    Every car is going to break something some time.
  9. #9 Re: The BS that is Pontiac's ABS Sensor.
    Banned - Busted For Scamming
    Feb 2009
    You do realize the reason why automakers went away from an external tone ring and sensor is that debris could get caught up in it and mess it up. The integral design is more reliable in that sense, but all sensors fail sooner or later. Get a brand new one from your parts store for $75 and shut up.
  10. #10 Re: The BS that is Pontiac's ABS Sensor.
    Donating Users Ibwrong's Avatar
    Oklahoma City
    ^^ I agree, both of mine have the wires cut off and they are about 75bucks a piece and take basic hand tools to replace. Doesnt take a mechanics knowledge to do this.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  11. #11 Re: The BS that is Pontiac's ABS Sensor.
    Kansas
    Pwned
    SOLD 1999 GT Silvermist TS
  12. #12 Re: The BS that is Pontiac's ABS Sensor.
    Oklahoma City
    Hell you could have two of us fly out to Florida and pay for the hubs and still be cheaper than paying your mechanic!!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  13. #13 Re: The BS that is Pontiac's ABS Sensor.
    SE Level Member 00 grand prix's Avatar
    utah
    welcome to pontiac world,i had to replace BOTH HUBS and it cost me 605.00 dollors,it aint cheap if dealers do it,DO IT YOUR SELF
  14. #14 Re: The BS that is Pontiac's ABS Sensor.
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Imports>Muscle.
    Yes, GM does bad designing. My car says my left front wheel bearing is bad. I usually recognize a bad wheel bearing by a growling sound. Mine is silent. BUT.... my abs and tcs light say otherwise.
    Don't start on BMW. I own one. They aren't much better than GM. They have s**t quality electronics. Terrible power window regulators, notorious for bad steering angle sensors, which trigger tcs and abs lights, crap wood grain interior trim which cracks and looks terrible. The only 2 things they do well is handle corners like no other car that is as heavy as a bimmer and they tend to RUN forever if taken care of. However much BS you want to fix along the way is up to you.
    Again yes, GM made a terrible design by building the abs sensors into the hub. You are right on that.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  15. #15 Re: The BS that is Pontiac's ABS Sensor.
    GTX Level Member Deimos's Avatar
    iowa
    Or get a Timken one for 80 bucks I know cuz I've done it
  16. #16 Re: The BS that is Pontiac's ABS Sensor.
    Oklahoma City
    Quote Originally Posted by Deimos View Post
    Where did you get the Timken one at? Did you order straight from Timken?
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  17. #17 Re: The BS that is Pontiac's ABS Sensor.
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Timken ftw if you haven't got one already. You can get them at autozone price match it with one from advance (they carry national and NTP made in china) because they both have a 1 year replacement save money, and get something that is still made in the usa has great quality and has a warranty.
  18. #18 Re: The BS that is Pontiac's ABS Sensor.
    iowa
    Barrons bud
  19. #19 Re: The BS that is Pontiac's ABS Sensor.
    Wooster, Ohio
    wow your mechanics rip you off! its literally a 20 minute job if you know anything about a car. if you can do your own brakes you can do a bearing and you can get a cheapo for like 70. Buy a kia with a stupid long warranty and quit *****in then!
  20. #20 Re: The BS that is Pontiac's ABS Sensor.
    St. Louis Mo.
    Here............Use my write up. It will take you maybe 30 minutes top. That's taking the wheel off and then removing all bolts needed and reinstalling afterwards. You might need a breaker-bar to help with loosening some of the nuts as they probably haven't been touched since the car was first put together.
    http://www.grandprixforums.net/f73/h...ubs-10985.html
    I have to agree with everyone else, who the heck told you it would cost $500 bucks to replace ONE hub? They are seriously wacked out!!! And if it was your father, mmmm I would hate to say it.........but he's mmmmmmmmmm WRONG! And so is the idiot who priced the repair cost for you.
    Also ZZP has hubs $89 or 99 bucks a piece. The Timkin*(yeah its misspelled) are probably the best aftermarket hubs out there. Me personally, when I changed one bad hub, I went ahead and replaced BOTH front hubs. Why? It will save me time later when the other would eventually wear out. Also it gives me a spare incase of direr emergencies
    James Shafer
    St. Louis MO
  1. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
  2. '92 GTP M-284 ECT/CTS sensor
    By kmckirryher in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-15-2008, 10:03 AM
  3. bad sensor maybe
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 12:28 AM
  4. O2 sensor
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 04:01 PM
  5. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
