Thread: Never rains...
Results 1 to 6 of 6
  1. #1 Never rains...
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    On Wednesday, I took my '04 L26 in for the valve cover recall (you know, the one where they let us know in October, but they didn't have the parts, then they had the parts in February, but then they didn't again?); they did whatever it was they were going to do... but then the service advisor gave me a laundry list of things my car needed, including:
    Oil pan gasket,
    valley pan gasket (and because of that, the upper intake gasket as well!),
    struts,
    brakes,
    front axle seals,
    Add to that the gearbox is starting to go out, doing a number where it "slaps" whenever I touch the accelerator and when I start from idle it acts as if I'd been in neutral then gives an almighty yank! I'd changed the fluid & filter in January, and reset the adaptives, but those adaptives had maxed out again within days! So... I have to ask myself: how long can I nurse this motor along for? I'll need a car to be in tip-top shape for fall, when my road trips between Moline and Joliet double every week, but I can't keep pounding sand down a rat hole, nor can I just go buy a new vehicle! ...Though I've had my eye on a Mazda CX-3, to be fair; it's got the essential must-haves, including heated leather seats and HUD!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  2. #2 Re: Never rains...
    SWPA
    If the car is going to start nickel and dimeing you then it will cost less to get another car.
    My hope is to get rid of mine before it starts doing that to me.
  3. #3 Re: Never rains...
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    that was aweful sweet of em to do a full inspection for ya when you just took it in for a valve cover gasket. i bet they already had a date circled for when they could do the work for ya.
    i still need to make an appointment to get mine done .
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: Never rains...
    Mar 2014
    Tucson
    Depends. If you're talking about a "dealership new" car, no way. It's cheaper to fix what you have.
    If you're talking about another used car, maybe... If you get lucky and find one that has just been gone through or was very well maintained. You could also be buying a turd that puts you right back where you were with you're previous vehicle.
    9 times out of 10, you're better off financially to fix what you already own and have paid off. The only reason to get a different car, is because you want a different car. There's nothing wrong with that.
  5. #5 Re: Never rains...
    Dec 2014
    Moline, IL
    I have to keep nursing my car along for a while longer, I'm afraid. I just hope I can get a chance to replace my gearbox, otherwise that's the big determining factor... well, that or else I win the lottery, in which case the next Grand Prix I get is a 1967 ragtop and the '04 gets part-exchanged for new!
  6. #6 Re: Never rains...
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Oil pan gasket and axle seals can drip for a long time before they need to be replaced. Keep an eyeon fluid levels. Brakes you need, valley pan aka LIM gasket is a maybe.
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  1. It never rains... (or, washer woes 2016 edition)
    By April Thompson in forum The Rant Forum
    Last Post: 01-19-2016, 02:13 PM
  2. Passenger floor wet when it rains..05 GT
    By nickleahy23 in forum General Tech Discussion
    Last Post: 10-24-2011, 05:54 AM
  3. Stumble after it rains
    By Blackbird87 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-09-2011, 03:28 PM
  4. Every time it rains
    By zildjian102 in forum General Tech Discussion
    Last Post: 04-26-2011, 11:30 PM
