Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The evap purging is a different symptom and you will see the fuel trims go severly negative for no apperent reason which is really just the pcm compensating for the excessive fuel tank vapors that are being expelled into the engine. When the above mentioned condition happens the car will have perfect fuel trims driving down the road, in town, highway, it doesnt matter, and then out of the blue you will notice that the fuel trims start climbing up until they max at +16.4 and is never a negative number. It will stay locked at +16.4 indefinately until you give it a lot of throttle quickly or as Ryan mentioned above a high speed coast down. For the majority of the people that I have talked to about this problem their cars were stalling coming up to a stop light or it will badly surge and then cough out.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Barksdale AFB, LA
    I have never seen my LTFTs positive. I guess my PCM doesn't have this issue. I need to go back in the PCM and see how I have the codes programmed. I know it doesn't throw the code as it never shows on any reader.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Turning the codes off in the tune only hides the fact that the rear 02 is not present or throwing a code but has no effect on the pcm running the cat diagnostics, you just never see a trouble code simply because it is turned off. This also seems to be hit and miss and there are many guys that have never had this problem while some have had the problem and dont know why or how to fix it.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
