Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Bastard Reptile's Avatar
    Kansas City, MO
    I'm running into this issue with a friend with an '03....I'm gonna see if this helps he mpg's out.
    Thanks for the info!
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Hoffman/Schaumburg, IL
    Maybe this is why my LTFT's have been off for so long...... It will need to be set back to non-reporting though if you want to pass emissions
  3. #3 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Got the updated software today and I tried it out on the '05 Monte. IT WORKS. The cat diagnostic does not run at all with the new settings (disabled via coolant temp qualifier and maximum number of tests allowed per drive cycle set to 0). The fuel trims work normally and AFRs are right where they are supposed to be (and nothing locks full rich ever like what it was doing). I was also able to disable all rear O2 codes so those would never set either.
    I am now working with my tuning software vendor to get these parameters added for all 01-up applications supported.
  4. #4 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Quote Originally Posted by Reptile View Post
    As far as I know, HP Tuners software does NOT have this ability yet (if that's what you are using). All they allow you to disable is the COT (cat over temp) diagnostic which is NOT the same thing as this cat diagnostic I am talking about.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
