Thread: Identify obscure part, and how to replace
Results 1 to 5 of 5
  1. #1 Identify obscure part, and how to replace
    Sep 2014
    Cleveland
    Accidentally broke the lower plastic piece that secures the the Coolant Reservoir from bumping into the pully system. I've found a few at the local pick and pull, but I can't figure out a good effective way to remove them without breaking something along the way. Considering just ordering a new one, but not sure what the actual part is called or the part number. Any thoughts on what the part number is, or how to remove one already installed? I'm new to this.
    Thanks in advance
  2. #2 Re: Identify obscure part, and how to replace
    Sep 2014
    Cleveland
    I forgot to mention, 2001 GP GT
  3. #3 Re: Identify obscure part, and how to replace
    There's a push pin in the center. Pull it out, then the piece will pop right out.
  4. #4 Re: Identify obscure part, and how to replace
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Usually has a small slot in it, you can use a flat head to pop the middle part up, then pull with finger or needle nose pliers to just pull on the middle part.
    04 GTP -HAI, 1.9 rockers.
  5. #5 Re: Identify obscure part, and how to replace
    Feb 2010
    TN
    What they said small screw driver I just grabber one two weeks ago
  1. help me identify this part
    By aeraxeur in forum General Grand Prix Discussion
    Last Post: 07-17-2013, 09:29 PM
  2. Can anyone identify this part?
    By JoeinMN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2012, 11:15 AM
  3. Anyone able to identify this part?
    By txslow6 in forum General Tech Discussion
    Last Post: 01-17-2012, 08:59 AM
  4. Identify Coolant part
    By stmkl in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2010, 07:53 PM
  5. Identify this m90 part.
    By 04CompG in forum General Tech Discussion
    Last Post: 10-09-2008, 11:20 PM
