Thread: 2001 3800 Series II Supercharged Motor Issues HELP ME!
Results 1 to 20 of 25
  1. #1 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    Hello To All!! This Is My First Post And I Hope And Pray Someone Can Shine Some Light On My Issue....... I Own a 98 Lumina LTZ I Tossed The 3.4 v6 and Built A 2001 GTP Motor and Tossed It In Here Is The List Of Mod's......
    2001 GM 3800 Series II V6, ZZP Full Length Stainless Headers, Ported and Polished Heads, Comp Cams "Hot" Roller Cam, 1.9 Roller Rockers, Double Valve Springs, Polished Upper and Lower Intake, 3.5 Supercharger Pulley, ZZP Stage 1 ECM Tune, K&N 4 Inch Cold Air Intake, Accel Coils, MSD Street Fire Plug Wires, E3 Spark Plugs, 2.5 Stainless Exhaust, Flowmaster 40 Series Mufflers and 3.5 Inch Polished Tips, ZZP Strut Tower Brace
    I Recently Been Having Some Issues With The Motor Not Running Right.... It Seems Like Its Lacking Fuel But I Have Good Pressure To The Rails I Changed The Fuel Filter, Crank Sensor, MAP,TPS,Air Idle, Mass Air and Plugs And Coils Plus ICU!! It Runs Great For 30 Seconds Or So Then Stumbles and Sounds Like Its Loading Up It Will Clear Itself Out If You Up The Idle To 2500RPM or so as soon as you let off its back to lacking power and spittin and then finially quits.... Turn The Key Off and Wait 5 Seconds or So Start it and it runs good for 8-10 seconds then back to the issues....... I Just Came Home From Town One Day and Went Outside 20 Min Later and now its doing this.... There is no security light or engine light i hooked a scanner to it and got only a O2 Code and A/C code ( No A/C Pump)
    ANY INFO WOULD BE SO HELPFUL I BEEN AT THIS FOR OVER A WEEK AND I AM AT THE END OF THE ROPE
    PLEASE PLEASE PLEASE HELP!
  2. #2 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    antioch ill
    well i can tell you to use oem coils those are the only good ones for the 3800 motor
  3. #3 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    I Did Pull The Accel Coils and Stuck The Stock Ones Back On... I Got Great Spark and Good Fuel Pressure But Still Am Having Issues
  4. #4 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    What are the exact codes?
  5. #5 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    start by changing the ignition coil module
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  6. #6 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    What are double springs? Get rid of those junk plugs and you can't run a cam with 1.9's.
  7. #7 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    The Boss Iceman6669's Avatar
    Jun 2011
    Ok dumb question but I didnt see you list injectors anywhere... Did you do those also? and if so did you have the tune adjusted for it?
    2011 F-150 Yote powered
  8. #8 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Firs thing I want to know is the cam specs.
    Because if whatever it is, coupled with the 1.9's, without proper valve guide milling, will cause issues. Factory guides only allow up to .550"~ of max lift.
  9. #9 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    I Did Injectors I Do Believe There Lucus 42.5lbs And Im Pretty Sure There 1.9 Rockers I Could Have The Digits Mixed Up.... I Had The Car Fully Tuned At Beyond Redline In Green Bay, WI ($250) I Put A Total Of 8000 Miles On This Whole Set Up These Are The First Issues I Encountered I Also Took Out The E3's And Went To Autolight 104's
    Were is The engine coil mod actually at??
  10. #10 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    • 212°/224° at .050"
    • Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
    • Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
    • 116 Lobe Separation
      You Were Correct They Are 1.6 Rockers
  11. #11 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    icm is the part that the harness bolts into under the coil packs.
  12. #12 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    Okay Thats What I Thought... I Changed That Also Actually Twice Just To Rule It Out.... It Honestly Sounds Like A Tractor at Low Idle Real Choppy Then Idles To Almost 500 RPM and Then Just Up And Dies
  13. #13 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Quote Originally Posted by 97Luminaltz View Post
    Those are the specs WITH 1.6:1 ratio rockers (which are stock ones)
    If you have 1.9's, then that changes the ballgame you're playing...and you'll need milled valve guides to run those rockers.
  14. #14 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Video might help too.
  15. #15 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    I Am Tryin To Add A Video But Wont Let Me I Cant Even Add Pictures!! I Jerked The Valve Cover Just To Make Sure And I Was Correct There 1.9 (I Am Going Threw My Parts List As We Speak) Maybe It Is Just Fuel Pressure Regulator??? Just Came To Mind Is All
  16. #16 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Did milling the guides mean nothing here?
    If you don't have clearance for the maximum lift you're getting with those rockers and cam, why are you trying to replace other parts when you haven't answered if the heads are clearanced for your current valvetrain setup?
  17. #17 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    yes heads were milled and ported and polished att Extreme performance center in cecil wi
  18. #18 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    The guides, not the heads themselves.
    Are we on the same page here?
  19. #19 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    I am positive that they were car wouldnt run right if it was the other way... like i said i put over 8000 miles on this whole set up and just started having these issues
  20. #20 Re: 2001 3800 Series II Supercharged Motor Issues HELP ME!
    Jan 2013
    United States
    so i used a scanner and once again its only telling me that my O2 sensor is bad or what not and that i have no A/C connection..... maybe its time to just toss in the towel and buy a mopar....
  1. Replies: 2
    Last Post: 09-28-2012, 01:19 PM
  2. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
