it will be like an unexpected christmas :D
my pcm came quick as hell and I had good communication throughout with the guy
^^^^mine too. First e-mail took a couple of days but after that no problems and agreat product. Try to pm him on G P O N A
Paid night of nov 23 and first delivery attempt was made dec 2.
Works great, little unsure of the shift point (6100?). Other than the communication issue it seems to be going just fine.
Question: If the DIC is flashing zero on every mode, is it because the PCM is learning or because I didn't hook it up properly?
If it is higher than 6100 then their is a delay between shift command and the actual shift. This happens more with higher milage trannys. Its probably fine, it bothered me at first because I was so use to the stock shift points but you will get use to it and like it. Shift kit will help too.
so ur saying u paid for a pcm on the 23 of this november and recieved it yesterday. . . . quick question. for what model year did you purchase????
'02
oh ok, so do you think ill be able to order an 05 and get such a good turn around or i don't know not get the same service. . . . (i guess my question is should i take a chance and order one given the whole not answering emails situation)
will the car crank???
i would not run it tho and send it back.
ha thats kinda funny. i dont now. i was curious if it did that and still cranked. obviously its not bricked.
You can easily find solution for your problems on google search or on several websites.
Hi every one.
I don't like to stick my nose in other peoples buisness.
I know Will well and will pass this info onto him so he can respond to the questions at hand.
Overkill get swamped with P.M's and reply's from all over, and i know i would hate to be the one to open his E-Mails :)
I hope this helps you all out.
Happy new year to you all
Thanks for that update. Glad to hear all is well.
Another note: my issues have been resolved.
