The input clutch piston isn't a common thing to replace in a rebuild. It has to be inspected, and ordered separate if it is found to be worn, so it may be original. What do you mean transmission control solenoid? You probably mean shift solenoid for 1-2. I'm not sure if that can cause the problem you're having. Someone who knows more about 4t60e's would have to stop by.
