There are two soleniods that control shifting. For the first three gears to work properly, they both have to be working properly. the only thing that might hold fourth up from working is likely the shift cable position.
I have been having some trouble getting the key out, I would have to play with the shifter and it would come out. Also I notice the shifter may be in neutral and be in 4th gear. Maybe when the previous owner had the tranny done they didn´t adjust the linkage. What should I be checking for and how is it adjusted.
I know it has to be something like that because the fluid is not burnt, the car shifts great and yesterday I took it on the parkway and had no problems.
