Thread: 96 4t60e dont move when cold
Results 1 to 8 of 8
  1. #1 96 4t60e dont move when cold
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i dunno much about this car, its a 96 gp se 4t60e 4 spd. the car came and the trans will not go in reverse or drive, under high engine rpm u feel it trying. if you wait til the car warms up it will work, i took it down the road when it first came at it drove fine, tcc worked good. today i found a vacuum leak on the vacuum module line, repaired it and it changed nothing. my feeling is the pump is going out or weak? any ideas?
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: 96 4t60e dont move when cold
    I've heard of this issue before, don't know what causes it. Buddy found that letting it warm up for a minute or two was the key to getting it moving. Overall the trans isn't happy and probably needs to be rebuilt.
  3. #3 Re: 96 4t60e dont move when cold
    Pa
    If the fluid is full and the filter is installed correctly it sounds like the input clutch seal is bad/hard/rolled
  4. #4 Re: 96 4t60e dont move when cold
    Nov 2009
    Richmond, VA
    My 97 GT does the same thing. Running the shifter through the gears and letting it sit in '1' for a short time will usually get it to catch. Once it catches in '1', all the gears work. Revving doesn't seem to help. I drive in '3' until it warms up because it has a delayed downshift into 1st when I stop and will sometimes slip when starting from a stop or turning a corner slowly. Once it's warm, it's fine.
  5. #5 Re: 96 4t60e dont move when cold
    tennessee
    mine does the same 1994 with 100k also my fulid smells burt
  6. #6 Re: 96 4t60e dont move when cold
    PA
    Quote Originally Posted by kitt2000 View Post
    Change it all out. Burnt fluid is never good.
    2001 GSE
  7. #7 Re: 96 4t60e dont move when cold
    tennessee
    think it will fix it so it take gear easier
  8. #8 Re: 96 4t60e dont move when cold
    Nov 2009
    Richmond, VA
    I changed my fluid and added some Lucas, but it didn't help. Later, I took the return line loose at the tranny and let it run for a few seconds at a time to drain some fluid. Added a whole bottle of Lucas and it seems to have helped a little. I'm tired of spending money on this car, so I'm going to drive it 'til it gets unbearable, than I'll go back to 'old faithful', my 78 El Camino with a stone age, reliable TH350.
  1. 4t60e
    By Paul S in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-18-2009, 07:20 AM
  2. 4t60E and 4t65E case ???
    By 16MustangVet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2009, 10:47 PM
  3. Will a 4T65E got in a 97 car in place of a 4T60E?
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-24-2009, 05:23 PM
  4. need help with 4t60e
    By ez35 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-05-2008, 03:28 PM
  5. Help with 4T60E
    By rockthunder in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-23-2008, 01:11 AM
