Thread: Anyone know how to program for bigger injectors?
Results 1 to 3 of 3
  1. #1 Anyone know how to program for bigger injectors?
    Jul 2014
    Virginia
    Need to go from 42.5 to 80
    I really don't want to know what the numbers are I want to be able to do this myself in the future.
  2. #2 Re: Anyone know how to program for bigger injectors?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    stock flow rate is 36# (some sources say 33#)
    if you're using DHP, injector flow rate is msec / g. So you need to shave the time the injector is open.
    if using HPT I think the IFR table is g/msec so you need to increase the flow rate
    Multiply stock IFR by 36/80 = .45 (DHP) or 80/36 = 2.22 (HPT)
    if your IFR for 42.5# is already dialed in, then multiply your current IFR table by 42.5/80 = .531 or 80/42.5 = 1.88 for HPT
    then scan and dial in the MAF table again
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Anyone know how to program for bigger injectors?
    Jul 2014
    Virginia
    If I am dialing in the MAF tables for a twin charged setup how would I do that? will the maf sensor max out?
  1. Replies: 9
    Last Post: 09-05-2015, 07:04 PM
  2. Need a bigger spare for bigger brakes.
    By TheGerm in forum Tires & Wheels
    Last Post: 05-19-2013, 09:53 PM
  3. WTB: modded fuel rails/logs, and bigger injectors
    By 88formula in forum Wanted To Buy - Parts
    Last Post: 03-20-2013, 02:44 PM
  4. When to get bigger fuel injectors
    By RideWithPride in forum General Tech Discussion
    Last Post: 08-08-2012, 07:49 AM
  5. when to get bigger fuel injectors?
    By pontiacmanj2 in forum General Grand Prix Discussion
    Last Post: 05-31-2012, 02:21 AM
