Thread: Get a wideband AFR gauge or Dyno?
Results 1 to 11 of 11
  1. #1 Get a wideband AFR gauge or Dyno?
    SE Level Member onenayr92's Avatar
    May 2014
    Choctaw, OK
    I am really new to this forum stuff so excuse me if this is an old topic. I need to tune my car pretty badly. Should i buy a wideband AFR gauge and have someone tune it or just get it dyno tuned? A local shop does speed density dyno tuning. What should I do?
  2. #2 Re: Get a wideband AFR gauge or Dyno?
    Well, you can't speed density tune a 3800 anyway. The PCM is nearly 95% MAF based for every decision.
    If you are already modded and what not, you should already have a wideband anyway. The last thing you want to happen is for you to go lean and pop a piston or two. Then you'd be angry at the dyno people because you never knew what happened.
  3. #3 Re: Get a wideband AFR gauge or Dyno?
    May 2014
    Choctaw, OK
    I didn't know that you couldn't speed density tune them. That's good to know! Also, I found an AEM wideband with a Bosche 4.9 LSU O2 sensor for $150. Is that reasonable?
  4. #4 Re: Get a wideband AFR gauge or Dyno?
    If you looked at a L67/L32 tune file, you see that everything references the MAF sensor and very very very very little is the VE table used. It's more there for a accel. enrichment to help with the transition I guess. The VE table stops at 105KPA and the boost pressure will exceed 140-145KPA on stock motor. (6-8 psi)
    I have two AEM's sitting around already, they work fine for your needs.
    Do they make higher quality and better ones, yeah but close is good enough for what we deal with. We aint making 700+ hp to the ground with absurd boost numbers.
  5. #5 Re: Get a wideband AFR gauge or Dyno?
    May 2014
    Choctaw, OK
    Are you hinting at the fact that you will sell me one? haha If so I would definitely like to buy one.
  6. #6 Re: Get a wideband AFR gauge or Dyno?
    Oh, no I wasnt but it did make it sound like I was haha.
    But the AEM, Innovate MTX and Autometer wideband are all roughly the same price.
  7. #7 Re: Get a wideband AFR gauge or Dyno?
    May 2014
    Choctaw, OK
    Okay awesome. Thank you for input. If i get the wideband AFR gauge do you think just a normal tune would be good? A dyno tune is just a little out of my budget right now, but my car needs a tune pretty soon.
  8. #8 Re: Get a wideband AFR gauge or Dyno?
    reptile here sells canned tunes. or you can buy a tuner and learn to tune yourself.
  9. #9 Re: Get a wideband AFR gauge or Dyno?
    May 2014
    Choctaw, OK
    Do you know how much he sells them for? My car has a canned tune now, but ive done a few things since then. Intercooler and 3.0 pulley have been added.
  10. #10 Re: Get a wideband AFR gauge or Dyno?
    iirc hes about a $100. far cheaper then others.
    theres a thread in the for sale section.
  11. #11 Re: Get a wideband AFR gauge or Dyno?
    May 2014
    Choctaw, OK
    Thank you for your help! I PM'd him
  1. Need wideband gauge
    By Jeckel in forum Wanted To Buy - Parts
    Last Post: 09-22-2014, 04:25 PM
  2. Wideband Gauge.
    By DanPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2012, 05:19 PM
  3. Wiring Wideband Gauge
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2010, 02:05 PM
  4. Wideband Gauge Question
    Last Post: 11-02-2010, 04:31 PM
