Thread: Tuning non-TAPShift PCM to run a TAPShift transmission
Results 1 to 7 of 7
  1. #1 Tuning non-TAPShift PCM to run a TAPShift transmission
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    Unsurprisingly, no dealership technician wants to touch this with a 10-metre cattle prod... but how would I flash my PCM to operate TAPShift features? (I don't have the gearbox yet, but presume that'll go in!) I have already added the paddles, and both my clock spring and column wiring support it, so, in addition to the floor shifter, all I'd need to add in terms of hardware is the transmission itself (and I say that so glibly, as if it's "no big deal" )!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  2. #2 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    Kemmerer, Wyoming
    theoretically all you would need to do is get a gtp base tune that has tap shift already programmed and just load that tune onto your current pcm. I have no practical experience, and am just assuming that is how it would be done.
  3. #3 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    Buy a tuner. I suggest an HPtuner, because quite frankly they are better than a DHP, but a DHP is cheaper and through alot of blood sweat, tears and tons of money in your case, it could work..maybe.
  4. #4 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    Kemmerer, Wyoming
    hp tuner will work out of the box, without any hassle. and then you can use it to tune your car further. dhp is a good tuner, but the software is 10 years old, and has no support from the company that made it. hp tuner is easier to learn and easier to tune your car with.
  5. #5 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    bigger question is, have you found a tap shift tranny ???? hard to find. and all the inside of the car parts and harnesses and what not that goes into it?
    be easier to find a comp g in the end.
  6. #6 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You will not be able to "Add" Tapshift functionality with a tuner to a GTP Tune.
    You will be able to START with a TapShift (CompG) tune, and make it work, however the CompG tune also includes Stabilitrak. You would have to swap over to a CompG ABS module, and add the steering Angle Sensor, Yaw Sensor, and run a CompG Engine harness (There ARE differences in the ABS wiring, even though it's the same connector).
    I installed a TapShift transmission into my GT(P), but decided to go the other direction. I converted the trans to a Non-TapShift valvebody, but kept the 3.29 gears and other heavy duty parts. If I was to do it again, I would have probably done the whole Stabilitrak system. If you have a donor car, it's a lot easier.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  7. #7 Re: Tuning non-TAPShift PCM to run a TAPShift transmission
    Dec 2014
    Moline, IL
    I have access to a CompG at the boneyard; while the wiring's been cut by others, I can still salvage the leads for the Stabilitrak. Does anyone have any schematic of the traction/stability control wiring? I'd like to add the wires if I can before replacing the harnesses...
  1. T.T.T Tapshift
    By Speedy1973 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2014, 04:54 PM
  2. tapshift delays
    By GeeXPee in forum PCM Tuning
    Last Post: 06-15-2011, 06:35 PM
  3. tapshift schematics?
    By GeeXPee in forum General Tech Discussion
    Last Post: 06-15-2011, 04:41 PM
  4. how bad is tapshift?
    By BoostedComp in forum 04+ Specifics
    Last Post: 07-15-2009, 10:47 AM
  5. LS4 V8 DoD 4T65-E TAPShift info
    By Sinister Performance in forum 5.3L V8 (LS4)
    Last Post: 12-29-2008, 02:32 PM
