Thread: L67 injectors on L32 IFR help
Results 1 to 4 of 4
  1. #1 Re: L67 injectors on L32 IFR help
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I thought the only difference in l67/l32 injector was ev1 and ev6
    anyways the new IFR should be calculated by:
    the formula (old flow rate) / (new flow rate) = (some%)
    36 / 42.5 = 0.8470
    Therefore, 36 Lb/Hour injectors flow 84.70% of the flow of 42.5 Lb/Hour injectors. On that basis, you could multiply the IFR table for 36 Lb/Hour injectors by 84.70% to get the new value.
    If so, your table would now look like this;
    219--------------------185.493
    216.5-----------------183.3755
    213.49----------------180.82603
    209.36----------------177.32792
    206.51----------------174.91397
    208.08----------------176.24376
    207.78----------------175.98966
    207.48----------------175.73556
    207.23----------------175.52381
    206.5-----------------174.9055
    205.84----------------174.34648
    This would be somewhat richer than the example above, but maybe a good starting point. This is on stock fuel pressure.
    Edit:
    http://www.rceng.com/technical.htm That is a good site for formulas. As far as modifying the table you're just scaling based on injector as long as you don't change the FP.
    The big problem I see as to why these tables don't work perfectly is no one is considering the fuel pressure. We have different fuel pumps, age of the stock fuel system, filter conditions.
    The Lucas 42.5's supply 42.5 at 40# of fuel pressure per the spec sheet.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  1. WTB 42.5 lb injectors
    By 97AutoXVette in forum Wanted To Buy - Parts
    Last Post: 05-07-2014, 07:06 PM
  2. l67 injectors and tb on l36
    By l67ss in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2013, 09:30 AM
  3. ZZP 42.5 lb Injectors
    By SgtMarshal in forum For Sale - Parts
    Last Post: 11-21-2013, 06:44 PM
  4. 42.5# injectors
    By Nyc93 in forum For Sale - Parts
    Last Post: 10-24-2013, 11:59 AM
