download this application, read the directions on how to use it, it will do maf and ve tuning, as well as add timing. it is a really good tool.
http://theblattners.com/projects/tab...r/Default.html
and here is a link to a uv scan software application. you can use it to take scans, it is much better than the dhp scanner. hopefully the link will work
https://www.dropbox.com/s/g884dg0a6e...canII.zip?dl=0
