Thread: reading map, boost and vacuum with hp tuner
Results 1 to 20 of 23
  1. #1 reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    I'm trying to set up my gauges and charts to read map and boost with the hp tuner, but I'm not doing it right. there are directions in the help file, but I couldn't get it to work. is there a different guide I can read that says how to set it up?
  2. #2 Re: reading map, boost and vacuum with hp tuner
    Go into dropbox..find my config files and use it. Done
    All you should need to do is go into the table view, choose them there and when you switch to gauges etc.. they will be there. Then you format the gauges
  3. #3 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    that's what I did last time and was getting map kpa readings up to 400 and 150 lbs of boost.
  4. #4 Re: reading map, boost and vacuum with hp tuner
    You on metric or imperial?
  5. #5 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    Should be imperial
  6. #6 Re: reading map, boost and vacuum with hp tuner
    Buffalo
    Had this same issue. Never found a good boost / map setting for the gauges
  7. #7 Re: reading map, boost and vacuum with hp tuner
    another reason DHP is better? lol
  8. #8 Re: reading map, boost and vacuum with hp tuner
    Quote Originally Posted by ScottyDoggs View Post
    No way.. HPT is far superior in scanning and histograms. If you have trouble with readings/gauges either you are pulling the wrong item or something else between the seat and steering wheel is the likely issue.
  9. #9 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    My kpa readings go up into the 400+ range
  10. #10 Re: reading map, boost and vacuum with hp tuner
    Which item are you selecting to add to the table?
  11. #11 Re: reading map, boost and vacuum with hp tuner
    Apr 2015
    Columbus, OH
    Agree 1000% that dhp scanner blows. Have been using uvscan, couple days ago I decided to use dhp just because. There was so many missing cells, like it just decides to stop recording a pid and then starts again a minute later. Plus it only gives a max of 3 rows per second. Uvscanner gives 7-8/sec.
    How many data rows a second does hpt give?
    Top Swapped 01 Imp
    VS (very small?) cam, SD Headers, 2.8" pulley, 29°, ported everything, E85, AEM water/meth, Deka 60's, HPT tuned
  12. #12 Re: reading map, boost and vacuum with hp tuner
    Getting the conversion to read boost is hard, I've tried a few times. Then just gave up and learned to read the KPA as boost in my head.
    100 kpa is 0 psi, so anything above 100 is now boost. I'd see 140-160 kpa on avg, so roughly 6-8 lbs of boost.
  13. #13 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    I never said I was doing it right, but that still doesn't fix the problem
  14. #14 Re: reading map, boost and vacuum with hp tuner
    Which they shouldn't
    Are you trying to convert to Inhg and lbs or is this just you trying to get good readings that aren't 400kpa?
  15. #15 Re: reading map, boost and vacuum with hp tuner
    43lbs of boost eh, must be quick.
    Just upload the regular MAP pid in the table display, you should be able to change the way it reads out. MAP SAE, then under units click imperial default kpa.
  16. #16 Re: reading map, boost and vacuum with hp tuner
    Buffalo
    Bill, your drop box should be in your sig .......
  17. #17 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    I actually didn't add anything to the table. I just used the "billconfig" file that you said.
  18. #18 Re: reading map, boost and vacuum with hp tuner
    Kemmerer, Wyoming
    the hp tuner scanner doesn't really work like that. you can take a scan and export the data into csv format like the uv scanner software, but you can also set up a gauge display, a chart that will play all the recorded data, and set up a histogram to use for tuning.
    the data rate of the hp tuner is pretty good, but I'm not sure how many data rows it will do.
  19. #19 Re: reading map, boost and vacuum with hp tuner
    funny you say that. uvscan locks up on me 3 or 4 minutes in every damn time. tried a few versions too. all freeze up. even if im not logging.
  20. #20 Re: reading map, boost and vacuum with hp tuner
    Apr 2015
    Columbus, OH
    That's weird. I've never had it freeze. Are you using the original dhp box? Serial? I'm using the avt-852 USB version on Win 8.1. Tried changing the baud rate?
    Top Swapped 01 Imp
  1. 98 gtp boost reading
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2017, 06:38 PM
  2. Vacuum reading on 2000 GTP
    By K Kraziee in forum General Tech Discussion
    Last Post: 03-03-2014, 07:51 PM
  3. Scangauge 2 vacuum reading
    By charlie31603 in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2012, 10:10 AM
  4. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  5. No boost reading..
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2009, 07:53 PM
