Thread: idiot proof wideband histogram
Results 1 to 5 of 5
  1. #1 idiot proof wideband histogram
    Kemmerer, Wyoming
    trying to make an innovate mtx-l wideband histogram with the pro version. I set it up and it reads about 1 unit off. I tried to make my own custom histogram but it doesn't work. I thought the mtx-l was the same as the lc-1 so that is the predefined input I used, but it reads off. can someone give me idiot proof directions because everything I read doesn't make sense.
  2. #2 Re: idiot proof wideband histogram
    Arizona
    So then change the offset value till it matches.
  3. #3 Re: idiot proof wideband histogram
    Kemmerer, Wyoming
    do you just have to try and get it as close as you can? its hard to watch both sets of numbers at the same time.
  4. #4 Re: idiot proof wideband histogram
    Arizona
    You don't do that while the car is actually running you turn on hp and see your voltage coming in subtract the diffeence from your 5 volt or 1 volt whichever you have set and put the diffeence in
  5. #5 Re: idiot proof wideband histogram
    Apr 2015
    Columbus, OH
    On my AEM I can disconnect the sensor from the gauge. It will lock on 14.7 on the gauge and send that through the egr wire I've tapped into. Then just tweak formula to match what the gauge is reading.
    Top Swapped 01 Imp
  1. It's out... Proof.
    By 02 WS6 TA in forum Other Vehicles
    Last Post: 05-20-2015, 09:25 AM
  2. HPT trouble with histogram of Wideband
    By Beatdowncity in forum PCM Tuning
    Last Post: 12-05-2014, 06:17 PM
  3. Wideband, Histogram & HPTuners
    By rperry435 in forum PCM Tuning
    Last Post: 05-10-2013, 12:00 AM
  4. KR on the Chart display but not on histogram
    By Explicit_Spade in forum PCM Tuning
    Last Post: 09-16-2011, 07:02 PM
  5. bullet proof
    By nemesis in forum Visual/Body Modifications
    Last Post: 07-27-2009, 12:39 AM
