Re: Any way to have multiple tunes and switch between them, without reflashing?
roadrunner/moates does this to pcm's
Way over complicating this IMO. I can drive to a gas station on pump gas, fill up with e85. then swap pcm's toss the 2.8 pulley on and shorter belt with only a fist full of tools. I keep what ever pcm, pulley, belt im not running in along with the fist full of tools in a shoe box under the passenger seat or in the trunk. Literally takes like 15 min max to swap it over. I have a pcm tray in my car too so its simple....
I really need to make a vid of how long it takes me to switch from one pcm/belt/pulley setup sometime, ive explained this many times on here before aswell in other threads.
Seriously people its on of them if I can do it any monkey can do it kinda things no need to complicate it LOL!
98SandyVagVet
Sure, and who needs power windows? It only takes 5 seconds to roll down the manual windows. No need to complicate it with electronics!
Just kidding, but personally I like seeing what people do as far as customized electronic projects. I think it's pretty cool to see someone automate something even if it's not necessary.
Turbocharged400sbc
i believe that is for OBD1 only...
Impala131
Sure but last thing I want to worry about is something going wrong that controls well basically the whole engine/trans....... Piece of mind here is keep it simple and swap the PCM. When was the last time you had a window that doesn't roll up and down? If your answer is never then apparently you havnt owned enough w bodies LOL!!!!
Swap in a windows tablet for the radio? Nav, videos, touchscreen, Atuner?
