Thread: hp tuner serial/usb input software
Results 1 to 4 of 4
  1. #1 hp tuner serial/usb input software
    Kemmerer, Wyoming
    so I sent hp tuners an email and asked: I am wondering if you are going to support a serial/usb input from an auxiliary device like a wideband?
    I should have phrased my question a little different and asked if their software would be updated to support serial/usb inputs from auxiliaries like a wideband because the response I got was:
    unlikely with the current generation of hardware.
    I'm not sure if this is the correct spot for this thread. kind of a rant, but kind of a tuning question.
    what do you guys think?
  2. #2 Re: hp tuner serial/usb input software
    Arizona
    Why do keep complaining about this? Either get the pro and wire it up or wore your wide band into your system and scan it that way. I'm not trying to be a dick but I do not get the confusion or frustration with it.
  3. #3 Re: hp tuner serial/usb input software
    You don't want two separate inputs going into the pc to be logged as one. You want everything feeding in from one source. That way there can be no lag or different timing of the two items being logged.
    Hence the pro version with inputs on the side of the box.
  4. #4 Re: hp tuner serial/usb input software
    May 2012
    Where winter never ends
    Or just plug **** into plugs you don't need. AKA EGR
    Sent from my Nexus 6 using Tapatalk
    2000 Regal - Winter Beater
  1. DHP Software
    By Jeckel in forum PCM Tuning
    Last Post: 03-23-2015, 07:33 PM
  2. fob serial #....how to turn off the alarm without fob?
    By 97grandprix1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2014, 09:40 PM
  3. Adding VIN and Serial to Bin?
    By Pure2sin in forum PCM Tuning
    Last Post: 01-18-2012, 02:01 PM
  4. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
