Thread: Anybody with information on 04'-05' PCM's to narrow down a problem?
Results 1 to 7 of 7
  1. #1 Anybody with information on 04'-05' PCM's to narrow down a problem?
    GXP Level Member
    Mar 2015
    Tomball
    Ok so I am going on almost 2 months of troubleshooting this car (05' GTP) and I am not getting anywhere. I am stalled. I can see all kinds of information but it doesn't make sense.
    Car was bought with 3.4" pulley, slightly better exhaust. I replaced the plugs and wires with new stock wires. The car originally had a multi cyl misfire. Replaced that and the car would lay over as it was lean, loss of power. In trying to solve the problem. The car will not develop any boost most of the time (to 5psi occasionally then drop to 0").
    The car goes dead lean and backs timing to negative values at times under full throttle. If I stay in the throttle it will just lay over and after letting off the car goes into Reduced engine power, drops ABS and sets timing at 15* ATDC and dead rich. It will also allow small amounts of throttle input then drop out let off and it allows a little more but soooo little power. When you stop it cuts the accelerator pedal out completely. Turn the car off, open the door wait a few seconds close the door and restart like nothing happened. Usually gives an P0068.
    things I have tried:
    Added mechanical boost gauge.
    installed 3.8" pulley
    replaced baro
    replaced map
    installed stock airbox properly
    checked all vacuum lines using a hand vacuum pump
    replaced vacuum lines and used Ty wraps and a Ty wrap gun
    cleaned TB
    replaced MAF (Delco)
    removed SC and sealed off TB coolant passages and RTV'd the SC back on because no gasket available
    (did find loose SC bolt on forward side of SC and gasket compromised)
    Tested fuel pressure over 3 days, consistent 65 psi
    Replaced both knock sensors (due to KR at all levels of throttle and random)
    Other things I have tried:
    scanned using T app and timing backs sometimes to 12-14* and others to 0* 02 drops dead lean. Plugging the BBV causes computer to command less throttle than demanded and limits boost to 0 and causes Reduced power mode.
    If I can read KR it won't let me look at timing or 02 or anything else of value but when I did after replacing the knock sensors I get 1-2* sometimes it mostly at shifts or when coming out of lockup, I think you guys call that burst knock or something.
    anyway if someone knows of something that would help that'd be great.
    I am wondering if someone tried to reprogram the computer and screwed up. The car runs fine in NA mode and I just don't know what else it could be.
    Edit: most of the time it runs great NA mode, but every once in a while it stalls when taking off and goes dead lean and 0* timing and 0" Hg trying to accelerate at a slow pace. Actually have to get on it to get going.
    Also if I do a 1-2 run at WOT and it sets the P0068 it also sets a Low 02 output. Scanning it will go dead lean and the 02 stops switching if I press the gas lean let off rich. I have to stop the car open the door turn the car off wait a second and start it back up. The. It switches normally.
    thanks,
    Jeff
  2. #2 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    i think its time for a tuner to scan it and then tune it maybe. seems someone has messed with it already maybe.
    pretty sure you got guys in tx that tune. i know tx is huge, but you may get lucky and some one is close.
  3. #3 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    GXP Level Member
    Mar 2015
    Tomball
    I have a friend with HPT for his WS6 firebird and his 8.1L 3/4 ton truck but said I would be a slot or something to that effect. He's a guy I trust. Can the car be scanned without the credit or slot thing? He was saying about $90 or so.
  4. #4 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    you would have to buy the credits to unlock your car to tune the pcm. that would be your best bet if he knows what hes doing. id start out by just flashing a stock tune and see where that gets ya. then at least you can rule out the pcm. then tune it later on when the time comes.
  5. #5 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    You can scan any vehicle for free with hp tuners as long as the PCM is supported by them.
    Editing anything on the PCM costs credits.
  6. #6 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    GXP Level Member
    Mar 2015
    Tomball
    Ok, so can I have 2 PCM's for the same car? Like if I tune mine, I also bought an 04' PCM is that another credit or can I make them both the same or different calibrations without costing credits.
    eventually I will buy the suite, but for now I would just like it to run like it did when it was originally stock.
    Last time I did any engine tuning it was with EEC Tuner for Fords, and that's been more than 10 years ago and that section of my memory is nearly blank. I do trust Vernon he's one of my buddies from back then and had a high 12 second SC back then. He's still a master mechanic and is still into it. I had kids so my priorities changed for a while, now I have a little more time and decided that I wanted back in.
    Jeff
  7. #7 Re: Anybody with information on 04'-05' PCM's to narrow down a problem?
    GXP Level Member
    Mar 2015
    Tomball
    Ok so I installed a 04' GTP PCM did the relearn procedure and got it running. So after 2 days of driving I got onto it today and still highest reading I was able to get is 1.0psi, even when I ease into it, it will not go into boost.
    Jeff
  1. How to keep information on CD player
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 03-26-2015, 08:27 PM
  2. narrow band help
    By Freddy in forum Audio, Security & Visual Electronics
    Last Post: 08-08-2013, 09:30 PM
  3. Driver Information Center problem
    By BCGTP in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2011, 03:55 PM
  4. Erratic Idle Help me Narrow Down Please
    By 02GTGP in forum General Tech Discussion
    Last Post: 10-16-2010, 01:25 PM
  5. Narrow Band O2
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-06-2009, 10:59 PM
