Thread: Cant get DHP powrtuner to work windows 8
Results 1 to 20 of 24
  1. #1 Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    I have everything installed and when I try to connect to the car it wont register the cable. Any ideas?
  2. #2 Re: Cant get DHP powrtuner to work windows 8
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Right click and make sure you have it set to run as an administrator and run it in either XP or Windows 7 compatibility mode.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Cant get DHP powrtuner to work windows 8
    you need to install .net framework 1.1. then the com ports matched from the pc to the tuner. and match the usb speed and tuners speed.
  4. #4 Re: Cant get DHP powrtuner to work windows 8
    this thread i posted some of the com port stuff and speed settings. http://www.grandprixforums.net/threa...-for-DHP/page2
    im running win 7. i dont have to run as a adman or nothing.
    ive got a key span usb adapter, not sure how your hooking up. but either way you need to know what com port the usb is using. then tell dhp the same port #.
  5. #5 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Got the .net com/speed settings not sure what that means I need to change injector values for 80 lbers
  6. #6 Re: Cant get DHP powrtuner to work windows 8
    pics are in that thread. its shows where the settings are found. what usb adapter do you have? did you install its driver?
  7. #7 Re: Cant get DHP powrtuner to work windows 8
    Jan 2013
    Raleigh, NC
    80lb injectors? Jesus man. What kind of nasty big setup you got???
  8. #8 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Quote Originally Posted by chrsmi1 View Post
    stage 2 intense cam turbo kit 3" pulley dual intercoolers 9.5 or 9.9:1 pistons ported read manifold Front power log ported blower and LIM. Maybe some other stuff too.
  9. #9 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Still saying unable to connect it to interface after it says reading cable for 10-15 seconds. Any ideas now I changed the com ports around and the speed the only one where it says reading cable is com1 speed 115k
  10. #10 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Installed a new driver a working one. The light on the dhp is flashing red cant connect.... man this is disheartening.
  11. #11 Re: Cant get DHP powrtuner to work windows 8
    if you'd only answer the questions ive asked. maybe i can help.
  12. #12 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    I set the speed and com port the same as the one I used in the DHP. I did install the .net stuff. I tried running as admin. Also fixed the driver issue thst is an apparent problem eith windows 8. I think it may be windows 8 being a huge POS.
  13. #13 Re: Cant get DHP powrtuner to work windows 8
    you try running it in win 7 or xp compatibility mode?
    i pulled my hair out for 3 weeks getting mine set up. in person i can do it in like 30 minutes now. that includes the down load time. registering the cable when your do it right, that scroll bar that fails over and over, you never see it when it goes through.
  14. #14 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Tried xp sp2 not windows 7
  15. #15 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    I also just tried the program installed on windows XP still no luck. Terd sandwich city.
  16. #16 Re: Cant get DHP powrtuner to work windows 8
    how are you hooked up to the lap top? keyspan or radio shack adapter? or other?
  17. #17 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    Looks like it came off of a mac book or something. even when I just plug the tuner in without it being plugged into the laptop there is a flashing redlight. I cant find anything in the manual about that the guy I bought it from said it shouldnt flash
  18. #18 Re: Cant get DHP powrtuner to work windows 8
    Jul 2014
    Virginia
    I killed the battery on the car now I have to charge it... ugh.
  19. #19 Re: Cant get DHP powrtuner to work windows 8
    Jesus man! wtf does it say on the f ing adapter? who makes it? did you install a driver for it?
    i cant help if you wont reply properly. this is the 3 rd damn time im asking you this. and the last time...
  20. #20 Re: Cant get DHP powrtuner to work windows 8
    oh, and leave the charger on while you do the set up deal. and when you read and flash.
    its not a problem to do that. its also ok to have the laptop plugged in to a wall socket. its what i do when im working through my car. i got a piss poor battery right now.
    its not ok to power your laptop from a power inverter from the cars power port. thats a huge no no.
  1. Windows don't work
    By r803 in forum General Tech Discussion
    Last Post: 06-22-2012, 03:51 PM
  2. did install on 05 gp, now windows don't work.
    By traksta15 in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 06:41 PM
  3. Windows work only when raining
    By aminkel in forum General Tech Discussion
    Last Post: 06-14-2011, 04:35 PM
  4. Powrtuner w/ Windows 7 64bit
    By xxmattfxx in forum PCM Tuning
    Last Post: 10-27-2009, 10:45 PM
  5. Windows and radio will not work
    By PatrolmanA16 in forum General Tech Discussion
    Last Post: 09-21-2009, 07:11 AM
