now what? lol time to read a tuning guide now. Jerrys is pretty good. i just figured out how to use eddie's table modifier thingy. only working the maf for now. makes it pretty easy. most say not to bother ve tuning, so im not wasting the gas on it.
Personally.. I think not having the inputs on the side are a mistake. Reading their info on the 852
- 3 channels of analog to digital input (installed on request).
What would you use the additional imputs for?
Yeah that makes sense thanks
I've used it to log wide band O2 like Scott said, and a post charger/post IC temp sensor. Little stuff like that helps you to see the true correlation between say long runs and your post IC temps vs engine performance etc. Also helps see if your IC is keeping up or not.
Hey guys gtp owner using Hptuners and the tiny on my 2000 gtp have been trying to figure out how to get my dhp software to work so I can pull bin file. What avt works 852 as I have been working on adding tables to Eddie thingy. And would like to help out. run full open loop tune and ve seems to work for me and tuning with maf connected. Other thing I did change was my default air table just logged an average and remaped the default air table by hand seemed to level everything out. Was just going to buy an 852 but if someone knows it works then I'm Ordering.
Yes it works. I've used mine on multiple vehicles. Works great. Got it in early February.
I bought the 852 and it works perfect, and its pretty fast to
Sick on it![]()
Everyone just have default e setup or get all the add ons
Plan to use with ls1 free as well
I think this product is going to be a big deal in the community. Maybe a formal how-to and a sticky is in order, if anyone is up to the task.
K everyone have one question if the dhp software isn't registered will it register to an avt 852 thx
you dont need to register it. its free. tell the guys at the avt box place its to be used for dhp. they will set it up to work.
you need to register the cable tho, but thats only a term used for syncing up your pc to the avt box and dhp.
Thx buddy
Hey guys, I plan on buying an AVT Box very soon, and I was just wondering if it has any limitations that other tuners will be able to do. Also, I have spare keyfobs, and I was wondering if you can program them with the software or if that can only be done with Tech II scanners.
Also, how can I figure out what other vehicles I can play with using this box?
Thanks!
